whats the best shift points for a d16y7 in a ef sedan?
like the title says what are the best shift points?also what clutch kit do i order for my ef?its got a d16y7 out of a 96 civic in it with an l3 transmission.thing is i ordered kit for 96 and it wasnt even close to matching up.ordered one for an 88 and it was still a hair off what the deuce
Re: whats the best shift points for a d16y7 in a ef sedan?
I wouldnt take it past 7k. Those y7 bottoms ends are notorious for spinning rod bearings because of the weak oil pump.
EFB055
i run it just under 7 grand now so since they have week oil pumps do i try and find a better one?i need a good performance clutch kit for the car i have a stage one that should be here tommorrow but its just the disc.i need a new flywheel and pressure plate too.
You could put a different oil pump in it, and that would help. But you really need to get a new one and port it out to really be safe at elevated rpms and power levels. Search DIY oil pump porting for more info.
boostedefhatch
03-01-2009 01:17 AM
