traction bar question
is there SUPPOSED to be slack between the heim joints and the bolt that mounts them? I've had a blox traction bar and now another similar one and both have seemed to have heim joints with an opening so big that the mounting bolts allow it to slide back and forth when the car is loaded or unloaded (starting or stopping) causing an annoying click and an unwanted change in caster. do better brand bars do the same thing (eg full race, innovative, etc)???
Re: traction bar question
Yeah I don't have anything that looks like that. I bought this thing and it just had the rod end bolted to the control arm with a small cone spacer between. Do all double heim style bars use those spacers on the control arm side?
I have a client with the clunking noise when loaded or unloaded as well. Do the sell the spacer separately somewhere as pictured profab?
Looks like the only one that may last MIGHT be the Full Race. I ditched my traction bar in favour of the stock crossmember again because of clunking, less ground clearance, bolts loosening and overall just a crappy product (I had an ETD); plus it's illegal in SCCA classing anyways.
Some Co's use crappy heims to save a buck. The way to tell if Heim is bad if you grab the radius rod in the car. Bolts are tighten down. Go back and forward with the radius rod see if the middle EYE of the heim is stationary as the rest of the outside of the Heim moves. If there is a lot of play then may be bad.
Side to Side movement chattern low speeds or turning is the heim moving side to side... normal... when it gets loud flush the heim with lubricant such as WD this will flush out road debry and also lubricate and soften the noise.
Buy once! ESP FTW! Strongest on the market...
It's great to learn the hard way. Right? LoL
I was about to buy one (ETD and full race are on the top of the list) but so many unanswered questions
I am making the move to Solo II EP and road race GTL so are you saying its illegal?
Davegt27
Yes SMF, but also where I run in Canada CACC it's illegal in our SP, SPX classes. Don't buy the ETD, its garbage, I wasn't happy about how it's made.
Spacers are used because the width of the pocket in the torque box/mount is wider to accommodate standard bushings. When you switch to heim ends obviously its quite a bit narrower so you have to take up the space to prevent movement laterally. To a smaller degree, they are also used on some heims because the I.D. of the insert is a standard size and the bolt is metric giving some play or because a larger heim is required for strength.
They are very common in the industry though, especially in the sprint car scene as they use heims on the end of pretty much every suspension and steering component. That picture is off speedway's site.
If you need an odd size or made out of an odd material just let me know. Personally, we try to steer clear of 6061 and go with 7075. The shear strength is much greater.
I have the ETD bar and have had zero issues with it, Ive had it installed for 3 years aswell. Great ground clearance, rad clearance, quality heims, quality hardware. And there a canadian company!
I take my "radius rods" off every winter and give the heims a good flush with WD40 and then give them some synthetic grease. You can upgrade to grease able heims aswell, I will probably do that with my next bar purchase
You can make a sleeve to locate the bolt inside of the heim.
You can also use crush washers on either side of the heim which will "fill the gap" and do essentially the same thing.
Torque the **** out of the nut/bolt, too. That will help.
Alternatively, get a metric heim joint and then have no slop issues. Or use an SAE bolt in your SAE heim and have no issues.
on these traction Bars with a stock motor do you eliminate the front transmission mount?
I see some that say B-series mount but none say stock mount
Davegt27
Davegt27
Thanks for the response
I called K-Tuned a little while ago, they said most people eliminate the front mount he said it was just a crash mount
Never herd of a crash mount but ok
I also asked him about anti-dive/ant-squat geometry he said they did not have any measurements/figures
So I guess am on a different page as to the whole reasoning behind the traction bar
I guess I should at least try the thing before I knock all the tabs off and rebuild it
Davegt27
Davegt27
7rrivera7
06-19-2009 05:46 AM
lowgman
12
07-08-2005 03:44 PM
