Borg Warner S362 vs PTE 6262 DBB Billet
Has anyone done any testing? Currently have an S362, debating switching over to a 6262. Is there any comparison data??
Moderator
Re: Borg Warner S362 vs PTE 6262 DBB Billet
They have, but you're not going to see a back-to-back comparison of the two on exactly the same platform. Both turbos are highly utilized but may be from two different kinds of buyers. Honestly, you'd just be making a lateral move with what you have. If it ain't broke, don't fix it.
Moderator
Depending upon which Housings/wheels are on your S362, not really. You could use the same money, and convert your S362 with a new backplate and S200 housing, and create a S262 which is more responsive than the much larger cover. If you have the .70A/R, your turbine wheel is larger than the 6262 anyway, and you could still keep that or swap down to a slightly smaller 74mm inducer. But again, it may cost a couple bucks (few hundred)
Otherwise, no. not really. won't be that improved, at least from my experience with them
Its a divided T4 .8x housing right now. Trying to get a little more response out of the motor.
i have an s362 as well, who would i contact in getting the cover and whatnot to create this
s262. would there be a very noticeable difference in response? thanks
allm0t0rsir
04-06-2004 01:02 AM
93B18
03-23-2002 08:03 PM
