b18 continues to die when idling
Old Nov 8, 2010 | 05:44 PM
d34th4ng3l's Avatar
Default b18 continues to die when idling
New to this forum,but have a question for all experts.I have a b18c in a 95 hatch with a garret gt35r turbo..i m runnin a victor x intake and an 80mm throttle body.the motors built to handle 700 hp so all the internals are top notch everything.1600 cc injectors,spoon cam gears,pistons,rods u name it..however I think my air fuels off which is causing the problem cuz I can run her just fine for about 20 min with no problems then wen I slow down to idle it dies and it takes awhile to start again.it runs from between 14 and 16..I got 8.5 mm plug wires and ngk bkr7e plugs. Timings right on as well. I have it set to idle about a grand cuz its tuned at 550 hp now. Well I told y'all wat I think the problem is...any suggestions are welcome and appeciated.
Old Nov 12, 2010 | 06:30 PM
matthew3of3's Avatar
Default Re: b18 continues to die when idling
Possibly an idle air control valve. Sometimes you have to adjust your throttle body plate so.
Old Nov 12, 2010 | 08:09 PM
jDMJeRk's Avatar
1600cc injectors are going to be tricky to get idle. You might check the throttle linkage. I had a similar problem and my linkage had too much slack in it. It shouldn't have more than 1/4" of play. Hope that helps
Nick
philep_cb7_91
Feb 21, 2010 11:28 AM
twentyhurtz
Dec 5, 2008 07:30 PM
dc5RickK20
Dec 3, 2007 07:19 AM
foumer
May 7, 2006 07:37 AM
walsredprelude
Oct 30, 2004 09:42 AM
