Wastegate touching A/C Lines? Why?
Old Nov 8, 2010 | 10:57 AM
Hobkins's Avatar
Default Wastegate touching A/C Lines? Why?
I have a turbo'd EM1 and right now my wastegate is sitting against my A/C Lines. I have a Blox manifold and some kind of Wastegate I was never sure what it was. Why do you guys think they are touching?
Here's pics
Old Nov 8, 2010 | 11:15 AM
kyden's Avatar
Default Re: Wastegate touching A/C Lines? Why?
looks like a cheap-o wastegate. just wrap that one line, you'll be fine.
Old Nov 8, 2010 | 11:21 AM
Garage 808 Hatch's Avatar
They touch because of the low budget parts used. Drag manifolds are horrible, and no matter what WG is on there, it will hit the line. Like stated above, just get a heat wrap for the AC line.
Old Nov 8, 2010 | 11:40 AM
Tootsie7944's Avatar
It's touching because you haven't pulled the lines back or re-routed them lol. Just get thermal heat wrap from JEGs, it'll be fine.
Old Nov 8, 2010 | 11:52 AM
Hobkins's Avatar
We have heat wrapped it and pulled the A/C lines back but I'd rather not have to do that. If I replaced the Drag manifold with a Inlinepro T3 would that fix that problem so that I wouldn't have to keep my A/C pulled back?
Old Nov 8, 2010 | 12:18 PM
lsturbo33's Avatar
I'm assuming it wouldn't help. Your wastegate placement on that drag manifold is pretty close to the head. All other cast units are going to mount the wastegate more toward the center and closer to the core support.
Old Nov 8, 2010 | 12:32 PM
b16racereg6's Avatar
maybe contact a vendor or sponser on the site and maybe they could hook you up with an elbow off it? i dont know how much room you have next to the powerstearing but its an idea G.L
Old Nov 8, 2010 | 12:44 PM
Hobkins's Avatar
Hmm...
Old Nov 8, 2010 | 02:04 PM
lsneo's Avatar
i have a 90 degree elbow just laying around for a 38mm elbow. Just shoot me a few bucks plus shipping if you want it.
Old Nov 8, 2010 | 02:54 PM
Axix24's Avatar
I would just use high temp heat wrap tape and then some exhaust wrap over that. And then try slightly bending the ac line a tad...
Old Nov 8, 2010 | 04:56 PM
Hobkins's Avatar
Would an InlinePro T3 turbo manifold be any better positioning for the wastegate? I'm just not seeing how my setup is touching lines while others don't?
Old Nov 8, 2010 | 06:11 PM
slywfbpsi's Avatar
what others? I just did a quick google search and saw 10 like yours
Old Nov 8, 2010 | 10:57 PM
Hobkins's Avatar
Hm guess I don't notice until I actually look for it.
Thanks all, guess I'll just keep it wrapped and pulled back a tad.
descartesfool
May 10, 2008 08:22 AM
Muckman
Apr 18, 2006 03:42 PM
turbochargeb18c
Sep 5, 2005 08:36 PM
yellow blur
Oct 7, 2004 06:22 AM
