New to Boost questions
Old Nov 11, 2010 | 10:29 PM
bcgump's Avatar
Default New to Boost questions
Ok i'm new here, and fairly new to FI. So go easy on me...
Heres my setup
95 DX hatch
d16y8 top, and bottom
eagle ords w/arp bolts
standard bore vitara 8.4:1 pistons
ACL racing series main bearing, and rod bearing
d16z6 cam gear
arp head studs
a polished crankshaft
with a new oil pump, timing belt, water pump ext
rev hard turbo kit t3/t4 50 trim
440cc injectors
p06 vtec conversion chip
hondata s200
Dont think I missed anything.
Just a couple of questions.
First what oil do you guys reccomend? Of cource mobil one synthetic, but what weight would be best? I live somewhere cold if that will make a difference.
Its on 8lbs of boost right now, but will probably go up to 12 soon after I finish the break in.
Its not my daily driver and it was tuned at 12psi, but I was wondering how safe you guys thought 12 lbs is, and if it is safe how high could I go before I started to get into that grey area where I might start breaking things?
Also, I havent been driving it in the rain, but was wondering if it was a bad idea?
Thanks I'd appreciate any advice you guys might have
Old Nov 12, 2010 | 07:09 AM
Pockygsr's Avatar
Default Re: New to Boost questions
come on you turbo gurus I know you're out there.
Old Nov 12, 2010 | 11:50 AM
93ls10.0's Avatar
15psi with those injectors is all i have seen people run. u use a y8 oil pump? been told the z6 pump is more solid at higher rpm.
TheProfessional
Jun 13, 2012 07:06 PM
wastedyouth2542
Mar 21, 2010 10:43 AM
madking411
12
Nov 17, 2009 08:54 AM
v8killer18
Aug 29, 2009 12:34 PM
sadangryboi
May 9, 2005 01:28 PM
