ls turbo question
Old Nov 2, 2010 | 08:58 AM
judd_123's Avatar
Default ls turbo question
I building a ls turbo motor for my crx the motor will have eagle h beam rods 81.5 mm probe forged pistons brain crower top end with 403 Cams with 450 dsm injectors skunk two manifold gsr throttle body and arp head studs gonna run ten pounds as my daily driver do you guys think I need a block guard and crank gridle thanks and ple!se post your opinions
Old Nov 2, 2010 | 09:06 AM
solo227's Avatar
Default Re: ls turbo question
no you wont need the block guard...
Old Nov 2, 2010 | 09:41 AM
Tootsie7944's Avatar
Definitely do NOT need either.
Old Nov 2, 2010 | 11:16 AM
jfoster's Avatar
I run 10psi on my stock LS...you should be fine.
Old Nov 2, 2010 | 11:44 AM
judd_123's Avatar
Thanks guys helped a lot . What's some thing s I can do too keep it from leaning out
Old Nov 2, 2010 | 01:28 PM
jfoster's Avatar
Thats going to be in the tuning... you might want to go with larger injectors and I didn't see a fuel pump or choice of tuning system in your plans??
Old Nov 2, 2010 | 01:35 PM
dc2luver's Avatar
yeah bigger injectors for sure. I can easily see those dsm injectors maxing out. I would recommend some rc750cc injectors (no need to wire in resistor box with these either). and a walbro fuel pump and you should be good to go. I'm running those injectors and fuel pump on my stock gsr on 12lbs and i have no problems at all and the car is my daily.
Old Nov 2, 2010 | 02:57 PM
judd_123's Avatar
Well I heard for just a low boost car to run those 450 dsm. This is going in a Crx and what size pump do I need to run pitch some ideas and I was gonna use pharable chip
Old Nov 2, 2010 | 04:35 PM
Silva Bullit DC4's Avatar
A Walbro 255 lph pump will do just fine. Those DSM 450's are gonna limit you to around 300 whp.
How much power were you planning on shooting for? You did not state what turbo you will be running, so try not to determine your goal based on psi.
Old Nov 2, 2010 | 06:02 PM
judd_123's Avatar
I gonna be running a t3 t4
Old Nov 2, 2010 | 06:05 PM
TheShodan's Avatar
Moderator
that doesn't narrow it down. "T3 T4" could be damn near anything
Old Nov 2, 2010 | 06:32 PM
judd_123's Avatar
Jdm sport turbo t3 t4 with a 10 pound spring
Old Nov 2, 2010 | 06:41 PM
ELIDA9's Avatar
Old Nov 2, 2010 | 07:33 PM
jfoster's Avatar
Please realize the chipped ecu will have a base map which will allow you to start the car and check for install issues, and hopefully drive to the tuner without going into boost. But the car will need to be tuned with a wide band 02 in order to confirm that the air fuel ratio is within the proper ranges. Boosting on a base map has killed many motors.
Old Nov 3, 2010 | 03:05 AM
judd_123's Avatar
Okay so what tune should I run and if I put the walbro 255 with those 450 I should be fine on the fuel part
Old Nov 3, 2010 | 07:12 AM
judd_123's Avatar
Wanting opinions on what tune also 450 or 750 cc injectors and should i convert to Obd1 now too if so who has some cheap harness for it
Old Nov 3, 2010 | 07:33 AM
dc2luver's Avatar
The injector size will be based on how much power you're trying to make. So how much power are you going for?
Old Nov 3, 2010 | 10:33 AM
jfoster's Avatar
I would suggest utilizing the the Tuner Directory HERE and locating a reputable tuner near you. And then discuss with them what tuning software they prefer to use to tune your car. There is no plug and go tune available, you will need to either learn to tune fuel and timing maps yourself, or pay a pro tuner to tune the car for you.
Old Nov 3, 2010 | 02:09 PM
judd_123's Avatar
I looking for 300 to 350 if my motor can make that with the parts I got. What bout converting to Obd1 anyone know where I can find some cheap conversion harness
Old Nov 3, 2010 | 03:12 PM
swappedcx's Avatar
I hate to be a dick and don't normally post if I can't help, but my god...does anyone even look at the forum before they post threads? I swear there is a epidemic of "block guard" threads recently. Every single question you asked could have been answered already if you would just search it.
And rywire should have whatever harness you need.
Old Nov 3, 2010 | 04:11 PM
judd_123's Avatar
Dc what tuned setup you running plus wanna about injectors to run
Old Nov 3, 2010 | 07:37 PM
If 300 to 350 is what you're shooting for, I'd suggest the saturated (high impedance) RC 750 cc's.
As far as tuning goes, read the post below again...
Originally Posted by jfoster
I would suggest utilizing the the Tuner Directory CLICK HERE and locating a reputable tuner near you. And then discuss with them what tuning software they prefer to use to tune your car. There is no plug and go tune available, you will need to either learn to tune fuel and timing maps yourself, or pay a pro tuner to tune the car for you.
Old Nov 3, 2010 | 08:03 PM
judd_123's Avatar
When running those injectors do I pull my oem resistor off is my HP goal possible with my build
Old Nov 4, 2010 | 03:13 AM
judd_123's Avatar
Bump for help
Old Nov 4, 2010 | 07:32 AM
dc2luver's Avatar
i have an obd1 harness. and all you do for the rc injectors is just swap them out with your old ones. I'm running 750cc's on my gsr (bone stock) and is making about 300hp on 12lbs
