How much psi can you run on a B&M fpr can you get 500whp with it?
Will a B&M fuel pressure regulator be able to go over 60psi and also whats the highest amount of psi can it be raised to,I would like to know this before I go out of my way and spend more money out of my budget.
Re: How much psi can you run on a B&M fpr can you get 500whp with it?
It's about boost, not power...
The stock diaphragm on the regulator likes to tear and become inconsistent at about 14-16 PSI, depending on the condition and age.
If you have ID1000's (meaning lots of injector), you can make 500+ WHP with a very efficient engine setup (B20/VTEC + cams and big turbo) and keep the boost low, and stay below 60PSI of fuel pressure.
It is boost that requires a better regulator. The B&M + stock unit doesn't like to hold anything above 60 PSI peak fuel pressure at the rail.
swoosh
03-05-2004 02:53 PM
