itr cam question
Old Nov 7, 2010 | 07:10 PM
CivSiClone_96's Avatar
Default itr cam question
Yo I picked up some ITR cams the other night for super cheap I got home and looked at them in the light and It looks like one cam is a 95-00 jdm itr cam and the other one is a 98-00 ctr cam does it matter if there ctr or itr cams?? is this going to affect anything with adjusting valves or boosting? there going in a LSV with a b16 head. Thanks for your time.
Old Nov 7, 2010 | 08:21 PM
ryguy2588's Avatar
Default Re: itr cam question
No it shouldn't matter. The newer ITR cams are pretty much exactly the the same as the CTR cams. I know that there is a little difference between the newer and older ITR cams though. But really its not enough to make a big enough difference in performance.
Old Nov 8, 2010 | 06:11 AM
HeitorD16's Avatar
I wonder what set of Adjustment Cam gears that are in use in B16A Boosted ITR Cams
Old Nov 8, 2010 | 06:18 AM
ryguy2588's Avatar
There are a lot of adjustable cam gears you can use...blox, skunk2, jun...the list goes on...
Old Nov 8, 2010 | 08:56 AM
HeitorD16's Avatar
I know, I use the cam gears BLOX, but wanted to know some setup, right? example.
I'm using:
-2 In the exhaust and intake at 0, wanted to know what best for my setup with B16A Turbo ITR CAMS ... I created a topic, but I depend on the approval of moderation for publishing the topic.
Thank you.
Old Nov 8, 2010 | 10:14 AM
jfoster's Avatar
I'm using:
Thank you.
You would have to put it on the dyno to check for gains at different settings. For the most part people tend to use stock gears with oem cams, and adjustable gears with aftermarket cams. Because in most cases oem cams perform best at 0.
Cam Gear Info for the search impaired
https://honda-tech.com/forums/showth...ight=cam+gears
Old Nov 8, 2010 | 12:23 PM
ryguy2588's Avatar
Ya most people use the stock cam gears or leave the adjustable ones at zero. You should let your tuner worry about all of the timing adjustments because he's gonna know whats best for your setup. I've heard that if you retard the timing a little bit, idk how much to be exact, but it increases hp a little bit because honda advances it for emissions purposes? I could be wrong, but that's what I've heard from friends.
D21X
Apr 27, 2017 08:50 PM
SobrietyRulesNA
Sep 9, 2013 08:56 PM
1995Civiccx
Sep 4, 2007 12:51 PM
turbo gsr
Oct 5, 2005 01:26 PM
RedGSR
Jan 29, 2003 06:47 PM
