Aem wideband install
Old Nov 1, 2010 | 07:12 AM
b16bri's Avatar
Default Aem wideband install
Thoes who have an aem wideband how did you install it. Black to ground red to switchd power source that has a fuse like a radio but what did you do with the white and blue wire ?
Old Nov 1, 2010 | 07:29 AM
LightningTeg's Avatar
Community Builder
Default Re: Aem wideband install
Why dont you read the instructions?
Old Nov 1, 2010 | 07:30 AM
Tootsie7944's Avatar
You should have a ground, a power wire, and perhaps a light power souce (unless your gauge is older and the light is always on). The other wires are your sensor wires and should plug into the 02 sensor.
Old Nov 1, 2010 | 07:31 AM
ashb82's Avatar
i put the red on 12v switch. You should ground it to the thermostat where the engine grounds are. i have read you should try to ground all your stuff to the same place on your car to stop unwanted noise. I run the white wire to d14 on the ecu. Blue wire is for a rs232 cable.
Old Nov 1, 2010 | 08:09 AM
Jeffro1265's Avatar
the black wire is your gound
the red wire is your power source (ran mine to the fuse box with the radio fuse.)
the white wire is your source.
the blue wire is not needed.
run a good solid ground with the black wire,
run the red wire to your fuse box
run the white wire to d10 or d14 pin on your ECU. either cut the old wire or splice it in. assuming you have hondata you can datalog with your wideband.
Old Nov 1, 2010 | 09:15 AM
komat's Avatar
you can just use your radio harness for power/ground
Old Nov 1, 2010 | 09:51 AM
dpetro1's Avatar
the bad thing about the aem is that the white wire is a 0-5v output so you cant really run it to d14. you cant use the aem to provide narrowband data to the ecu. and also datalogging from d14 is unreliable because it reads a max of like 3.7 volts.
OP, are you trying to replace your stock o2 with the AEM? if so you should run in open loop and just wire power and ground. then to datalog you can use the white wire to d10 (ELD, which is a true 0-5v input)
Old Nov 1, 2010 | 09:58 AM
ashb82's Avatar
I did the 0-5v mod on my ecu. It worked befor the mod just would not log values over 17.5 afr.
Old Nov 1, 2010 | 11:03 AM
b16bri's Avatar
Ok so red to switched power source black to ground and white to sensor voltage D10 on the ecu and leave blue alone ??. It will be used with hondata or ectune. Dose it matter if it's obd1 or obd2 ecu / motor meaning is it still d10
Old Nov 1, 2010 | 11:14 AM
ashb82's Avatar
what car is this in
Old Nov 1, 2010 | 11:32 AM
norcalB18's Avatar
What kind of noise are you talking about? Like the noise a TV makes when nothing is playing? My AEM uego wideband does that for somereason. Everytime i turn it on it makes the noise of a TV with no volume...
Old Nov 1, 2010 | 11:41 AM
b16bri's Avatar
It's in a 98 civic with an odb1 b16a swap in it
Old Nov 1, 2010 | 12:41 PM
dpetro1's Avatar
what ecu? obd1 and obd2 have different pinouts. i just always assume obd1 with tuning/widebands.
Old Nov 1, 2010 | 01:42 PM
Community Builder
Please dont post unless you have factual info. The AEM can do due nearst emulation (narrowband) via a switch on the back which makes the signal 0-1v. It has 4 positions (one is 0-5v linear, 0-1v narrowband, I dont know the other 2 off my head)
Nothing wrong with logging from D14. Sure it only goes to 3.7 volts, but that ended up being like 16.7 afr on my AEM. Thats higher then what you need to know.
AKA READ THE DAMN MANUAL
http://tunertools.com/prodimages/AEM...structions.pdf
Old Nov 1, 2010 | 03:11 PM
b16bri's Avatar
I cant read the manual becuase I didn't buy it yet i'm planning on buying it soon i was just curious as to what people did before i had to install it. And yes it's an odb1 ecu it's a jdm p30
Old Nov 1, 2010 | 03:18 PM
b16bri's Avatar
Also how do you test to make sure you have the correct volts and the ecu with a meter one lead to ground the other to the ecu pin
Old Nov 1, 2010 | 05:05 PM
Community Builder
I just linked it...
Old Nov 2, 2010 | 05:13 AM
dpetro1's Avatar
hmm, didnt know there was a switch. but then my question would be if you change the output to the narrowband then you wouldnt be able to datalog because you no longer have a wideband output. so you would have to pick one function or the other?
1) 0-5v output and datalog off d10 (or d14 if you want the reduced range). ecu in open loop
2) 0-1v output to d14 for narrowband simulation (no datalogging available). ecu in closed loop
Old Nov 2, 2010 | 06:57 AM
Community Builder
Well if your using a wideband to tune anyway, your going to have an aftermarket ecu. And every good aftermarket ecu I know of has closed loop built in that you can set parameters to, including what o2 sensor voltage to use.
At least with ectune you can just use 0-5v to log and use closed loop if you want.
So basically the only time you'd use 0-1v is if your running a stock ecu and are replacing the stock o2 sensor with it.
Old Jul 8, 2013 | 08:53 AM
pkopalek's Avatar
This thread has saved me lots of time (so that I don't have to switch to my Innovate LC-1, since I have the AEM gauge etc setup)
The white wire on the AEM gauge is going to go to d14 on my chipped obd1 Honda ECU.
I am using HULOG to get data to my laptop, and Crome Pro to datalog (which we've seen get 25+ plots per second, much faster than Freelog).
I'll report back, despite not being the OP. Was looking for conclusive information here, but this looks like I can keep my gauge installed and intact (for manually reading a/f) while using HULOG (which I have the 4 pins pinned out on the ECU for) into the laptop.
Technically, this is still 'using a wideband' to tune, but using the 'narrowband' simulated analog output for letting HULOG read directly from the ECU to plot MAP/RPM/A-F in order to tune.
Old Oct 6, 2021 | 07:47 PM
Sh!tBoxHonda's Avatar
Did your aem harness have a brown wire for a signal ground?
I'm doing the same thing with a newer aem uego model and it says it has red-+12v black-gnd white-signal positive brown-signal gnd. I ran both the brown and black to the sensor ground on the ecu and it's acting weird like during the heating process it just goes blank and shows the 4 lines
Old Oct 6, 2021 | 09:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Place the black wire on a good chassis ground all by itself and connect the brown wire to the engine harness ground at the thermostat housing. Remove both grounds from the ECU plug.
Old Oct 7, 2021 | 08:00 AM
I did that anthats still doing the same thing. It heats for about two or 3 seconds and the. The "needle" sweeps all the way to the end and just shows 4 line
Old Oct 7, 2021 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You may have damaged it by wiring it incorrectly in the first place. Also, it may not be wiring related at all... how long was the sensor installed into the exhaust stream before you actually wired up the gauge/system ???
Old Oct 8, 2021 | 03:20 AM
I didn't put it in until after it was acting weird. And Im pretty sure that the last owner definitely wired it wrong I'm just gonna do what I should've done and get a new unused one and it'll be an lc-2 instead
bl0nde.runn3r
Oct 28, 2008 08:19 PM
MrBryan
May 28, 2007 04:27 AM
Sirus
Oct 5, 2002 09:04 PM
R-1303
May 30, 2002 08:27 PM
