Vtec Solinoid oil pressure switch
Old Oct 28, 2010 | 05:00 PM
91 DA Revived's Avatar
Icon3 Vtec Solinoid oil pressure switch
I am about to start up my new build however this is the first time I have done a swap into a non vtec chasis. I have installed a built LS vtec in my 96 EK hatch. I dont see that my wire harness has a vtec solinoid oil pressure switch plug. is it required to use the oil pressure switch on the v tec solinoid or not. If not I will just run the one wire for v tec from the ecu if it is required I will need to find the 2 wire plug for it.
Old Oct 28, 2010 | 05:25 PM
EFPhilly's Avatar
Default Re: Vtec Solinoid oil pressure switch
you're in the wrong section....
one is for the vtec wire to turn on, other is for the ground (any spot). You will have to wire it.
See Are X
Sep 4, 2024 03:31 PM
TheIceMan
Dec 11, 2005 10:08 AM
jdmbreed
Sep 26, 2005 07:56 AM
Bimmerman
Jun 15, 2005 05:23 PM
