Need help on D16Y7(turbo) set up!?!?
Hey ive got a 96 civic dx and i was told by a guy that i could have 315whp if tuned right with this motor but all that im really aiming for is 270-300!!
Heres the set up that the guy has that tunes honda's:
Engine is a D16y7
Eagle H-beam Rods
Vitara Pistons
New Rod bearings
ACL Main Bearings
OEM head gasket
Walbro 225 fuel pump
OEM Timing Belt
new water pump
Crower Springs, Retainers, Valves
3-angel valve job (laskey Racing)
AEM adjustable cam gear
AEM fuel rail
ARP head studs
Edelbrock Intake Mani.
Throttle body
Zex 59300 cam
T3/t4 turbo with .63 exhaust housing
550cc injectors
Hondats S200
OEM motor Mounts
FMIC
Intercooler piping
Custom Down pipe
Dump Tube
Custom manifold (so I can keep A/C)
Greddy BOV
Tial 38mm waste gate
Turbo Timer
Boost Controller
Necessary gauges
Oil lines
Oil restrictor
^^is this everything i will need to obtain the goal of 300whp??is it even possible, if tuned right??if im missing any parts or anyone has a better set up plz let me know.....and im guessing i will need a Y8 tranny??
Engine is a D16y7
Eagle H-beam Rods
Vitara Pistons
New Rod bearings
ACL Main Bearings
OEM head gasket
OEM Timing Belt
new water pump
AEM fuel rail
ARP head studs
Throttle body
Zex 59300 cam
550cc injectors
Hondats S200
OEM motor Mounts
FMIC
Intercooler piping
Custom Down pipe
Dump Tube
Greddy BOV
Turbo Timer
Boost Controller
Necessary gauges
Oil lines
Oil restrictor
Re: Need help on D16Y7(turbo) set up!?!?
like im new to this and idek what some of this stuff is???lol but ik someone that will put it on lol
How much are you boosting? I had a BONE STOCK d15b with a generic turbo kit pushing 8 lbs , 440cc, on crome and I made 217. You have all the upgrades so 300 shouldn't be too hard
idk how much to boost bcuz ive seen a d16 boostin 27 psi on youtube and im still new to this so is that every part that i would need??(on the list, up top) if not can you add to that for me??
mntdewred
10-14-2002 06:41 PM
