acceptable compression on b18c1--turbo setup
Old Nov 15, 2010 | 06:04 PM
Droolin's Avatar
Default acceptable compression on b18c1--turbo setup
I've got a stock b18c1 with 220 compression on all 4 cylinders. The motor has 180k miles on it. I was wondering how well the motor would do with a turbo setup on it. Being that the compression is not at its highest. I was hoping for 300-350hp on a modest tune. Any and all info and opinions on this would be great. I have not done a leak down test on it. I was pretty content on the 220 across all cylinders. I have also wondered how much potential power i'll be losing b/c of compression if any. Thanks!
Old Nov 15, 2010 | 08:17 PM
AlexDphoto's Avatar
Default Re: acceptable compression on b18c1--turbo setup
it shouldnt be an issue. 220 consistently across all 4 cylinders is better than 250 on 3 and 200 on 1.
I dont see any reason why you cannot boost it
Old Nov 16, 2010 | 08:21 AM
lsturbo33's Avatar
Do a leakdown test on it if your worried.
Old Nov 16, 2010 | 08:24 AM
neverstop's Avatar
looks like a healthy motor to me but that's a lot of miles. just be sure you have money to rebuild it in case something lets go.
Old Nov 16, 2010 | 03:09 PM
GSRichard's Avatar
My freshly rebuilt motor was at 225 across all 4 cylinders...I have yet to find a definite answer on what the compression should be (NOTE: I built mine with lower compression pistons also).
Old Nov 23, 2010 | 10:01 AM
Droolin's Avatar
Thanks for the replies. Anyone else have any info on this?
Old Nov 23, 2010 | 10:56 AM
mtber's Avatar
If you are seeing 220 on all cylinders & the engine doesn't smoke under load & doesn't burn abnormal amounts of oil. It should be fine.
92integraVTECgsr
Jul 17, 2005 02:23 AM
siis2fast
Jun 16, 2003 11:09 AM
sjracer
Jan 21, 2003 03:28 AM
94TealGSR
Dec 3, 2002 08:24 PM
