turbo on a stock engine
Old Nov 3, 2010 | 05:30 PM
rez624's Avatar
Default turbo on a stock engine
stock 96 civic ex. wanna go with some minor boost.
1. how much boost could i run on a stock engine?
2. what components of a turbo kit would i need?
Old Nov 3, 2010 | 07:13 PM
phong3992's Avatar
Default Re: turbo on a stock engine
Depends on your setup..
Small turbo with 6 PSI than a Bigger turbo with 6 PSI will vary.. the bigger turbo will put more stress..
You need to be more detailed.. haha
Basic components of turbo kit is intercooler, intercooler piping, turbo, turbo manifold, downpipe, wastegate, blow off valve, injectors, tuning electronics..
thats the gyst of it.
Old Nov 3, 2010 | 11:22 PM
spawn_616's Avatar
thers a search function,thers also a thread of stock motors,u can run 40psi if u want,
u would need a turbo kit,coz u dont search,
350whp is safe
Old Nov 4, 2010 | 12:17 AM
komat's Avatar
350whp is not safe on a sohc...
Old Nov 4, 2010 | 07:57 AM
Schister66's Avatar
Man U FTW
Since you're running a D series presumably, your goals should fall in the 220-240whp range. Boost pressure, as you'll find through your research, does not mean much; therefore, set your goals as I did, in terms of power creation. The boost pressure required to hit that goal isn't much of a concern. The only time to ever care about "how much psi can i run" is when you're trying to stay within the confines of a MAP sensor or within the safe limits of your turbocharger.
As for the components you'll need, i believe you can find that information in the FAQ. You'll need all the typical components of a turbo setup but you'll only need those which can support the aforementioned power goal. Do your research and ask specific questions...you'll get more help then
Old Nov 4, 2010 | 12:05 PM
spawn_616's Avatar
my bad free slap,didnt read that it was d,appologies,
usdmgsrteggy
Nov 27, 2013 05:55 AM
Drake_ep3
Sep 5, 2008 07:29 PM
Madrat888
Jun 20, 2004 09:35 PM
jdmtegxsi
Jan 23, 2003 08:23 PM
