turbo j35
Old Nov 7, 2010 | 08:14 PM
CanadianEF9's Avatar
Default turbo j35
so my dad builds sand rails and we run the j32a1s and the j35a4 and everybody tells us that when you turbo them no matter how much boost your running you HAVE to run race fuel. we have customers running stock j35a4 on 5psi and running race fuel.... doesnt make much since to me cause their only 9.4:1 cr so how come on 5 psi on a j series you have to run race fues and a b series you can run 12 on regular?
Old Nov 8, 2010 | 05:54 AM
TheShodan's Avatar
Moderator
Default Re: turbo j35
that is incorrect. you don't have to run race fuel. "everybody" is wrong in your case.
Old Nov 8, 2010 | 07:42 AM
that is always what i thought and that is what i always told my dad but he never beleives anything i say. idk if it makes a difference but the motors are also turning 35in tires and are in sand so their under a little more of a load?
Old Nov 8, 2010 | 08:19 AM
2k.civic.si's Avatar
you could run a lot more then 5psi on that motor on pump gas
Old Nov 8, 2010 | 09:15 AM
Dueceification's Avatar
Im sure they will see some more load then what a car generally sees on the street. However more then likely they weigh less then your average street car. Like Shodan said those people are simply wrong.
Old Nov 8, 2010 | 10:09 AM
jfoster's Avatar
What EMS are you using to tune the fuel and timing?
Old Nov 8, 2010 | 02:57 PM
Axix24's Avatar
i think the reason people tell you to run race gas is b/c for extra safety. Hence there isn't really a ecu management to retard the timing on that motor just yet.... So the race gas would allow you safely to run higher boost on the high of stock ignition timing..
So, in theory, those people are correct..
Old Nov 8, 2010 | 03:01 PM
you can run an aem fic on that setup to control fuel and timing.
Old Nov 8, 2010 | 04:29 PM
rite now we have just been running the stock ecus. we just use a set of needle nose plyers to break out the security chip to run in the rails and for the turbos in front of the air sensor we put this thing on their with a glass ball that fools a sensor and for fuel we use the stock injectors but run a fuel pressure regulator that for every pound of boost it puts so much more fuel pressure.... and for like wiring in a j series motor into a civic should be pretty hard but i dont see why we cant use our sand rail wiring harness as long as you dont have to go through deq cause they are cut down to only pretty much everything to make the motor run and my dad does it all himself?
Old Nov 8, 2010 | 04:33 PM
He runs stock ecu, he cuts a full harness just to run engine only. And dismantles the ecu to only run the motor. Pretty sweet cuz it cost him nothing but an hour or 2 and a tuning shop is quoted 200min price for just the harness.
Old Nov 8, 2010 | 09:38 PM
jfoster's Avatar
This is what I expected. If you ran a programmable EMS like AEM you could run larger injectors, tune for a proper AFR, and most importantly pull timing per pound of boost ... allowing you to make more power, increase reliability, and run pump gas. You could even upgrade the fuel pump and injectors and tune for E85 and make way more power.
The cost of the EMS would be recouped after maybe 3-4 weekends of not buying race gas.
Old Nov 9, 2010 | 07:13 AM
http://www.aemelectronics.com/engine...oller-f-ic-12/
are you talking about something like this?
Old Nov 9, 2010 | 07:31 AM
Like I already said...you can use the AEM FIC
Old Nov 9, 2010 | 07:44 AM
highroller54's Avatar
pics of rails please!
Old Nov 9, 2010 | 04:04 PM
these are all rails that my dad built....
http://www.buggyfreaks.com/forum/viewtopic.php?t=2614
http://www.buggyfreaks.com/forum/vie...rails&start=50
http://www.buggyfreaks.com/forum/vie...r=asc&start=50
http://www.buggyfreaks.com/forum/vie...897&highlight=
Old Nov 9, 2010 | 04:12 PM
ashb82's Avatar
could they run a mega squirt
Old Nov 9, 2010 | 05:47 PM
NO!!!! screw mega squirt.... we had a ford 2.3 tyrbo motor that was mildly built with a mega squirt and wee took it to the dyno 4 times and it ended up blowing up cause it was running to rich.... the guys could not makt that thing run rite for their lives and we rebuilt it and put a stock computer to it and it runs like a champ to this day
Old Nov 10, 2010 | 04:41 AM
kyden's Avatar
sounds like a user issue, not megasquirt.
Old Nov 10, 2010 | 08:23 AM
jfoster's Avatar
Were you using it to control fuel and timing? or just fuel? My guess is just fuel and it blew because of too much timing. There are plenty of people dominating with MS, if you failed it's tuner error.
Old Nov 10, 2010 | 08:30 AM
ashb82's Avatar
i wasn't going to say anything
Old Nov 11, 2010 | 03:41 PM
it was a customer and idk what they did but between several different dynos they couldnt make it run
Old Nov 11, 2010 | 09:10 PM
Axix24's Avatar
that **** is garbage. Hondata needs to come out with something for the j-series soon...
Old Nov 11, 2010 | 09:11 PM
Axix24's Avatar
i never heard of a motor blowing up b/c its running too rich.. More like too lean?
Old Nov 11, 2010 | 11:00 PM
jfoster's Avatar
Care to elaborate on that?
Old Nov 14, 2010 | 03:48 PM
you have to realize when you are running to rich you get cylinder wash and that is what messes up motors and im pretty sure that big clouds of black smoke is not running lean
455bird
Oct 25, 2010 03:22 PM
RaceProfessor
Feb 26, 2008 06:32 AM
spockeg
Sep 1, 2006 04:26 PM
pkripper
Aug 23, 2001 03:37 PM
