Turbo Exhaust header
Old Oct 25, 2010 | 12:19 PM
fusion645's Avatar
Icon2 Turbo Exhaust header
I was curious on what is the best turbo exhaust manifold to get. I will be using a Gsr head with head work done like port & polish, and 3 angle valve job and will be running a Garrett 60-1 T3/T4 Turbo. Like i said I was curious on what turbo exhaust manifold to get. Thanks.
Old Oct 25, 2010 | 12:46 PM
jfoster's Avatar
Default Re: Turbo Exhaust header
You're going to have to do some searching as there are going to be many different opinions as to the "best" manifold.
Other aspects of your build will determine what manifold you want to some degree. Full or half rad, AC or non, etc. I went with a Blox mani as I am running full rad and AC. Tubular / equal length manifolds with a full 3" DP will typically yeild higher #s, but are not usually AC friendly and often require a half rad.
Start by finding some that you like and then researching others experiences with that brand on here. Cheap chinese manis tend to fail due to poor quality. Another reason I went with the cast Blox unit was the lifetime waranty. Some older manifolds have poor waste gate placement resulting in boost creep/spikes. GL
Old Oct 25, 2010 | 01:09 PM
bb6kid22's Avatar
im using a top mount, just be careful with those, it might not clear and you will have to cut your hood
i would have gone ram horn style if i didnt have to buy another exhaust, downpipe, etc
Old Oct 27, 2010 | 05:46 PM
fusion645's Avatar
Yea the AC is definitely coming out. I'll have to shop/look around but thanks guys for your input. I appreciate it.
tito1324
Mar 6, 2017 10:16 AM
jdm_vtec
Jan 22, 2008 03:29 PM
matto2413
May 22, 2006 06:00 AM
Briman2021
Jan 16, 2006 05:47 PM
b20blkcivic
Jun 18, 2005 06:47 PM
