Burning oil
Old Nov 4, 2010 | 09:07 PM
norcalB18's Avatar
Default Burning oil
So my built b18c block is burning oil but only at idle. Under full boost everything seems to be fine but when im at idle i get lots of smoke coming out my exhaust. Any suggestions? I checked my charge pipes to see if my turbo was blowing oil through it and it seems like all pipes before intercool have a very slight coat of oil in them but after the intercooler they're all clean.. could it just be my turbo seals going out ?
Old Nov 4, 2010 | 09:10 PM
Jdmefsir12's Avatar
Default Re: Burning oil
mine is doing same thing.. i can boost it and drive it and then when i stop at a light i get smoke for like 5 secs or so then it stops.. but i did oil change before i dynoed yesterday and i put 5quarts thinknig to much oil
Old Nov 4, 2010 | 09:36 PM
norcalB18's Avatar
I don't think i put to much oil into the motor though. And for your case you kinda stop burning after 5 seconds but i keep it burning constantly during idle. I'm really really really hoping its my turbo and not my blocks =(. Gotta run the scary compressions test tomorrow
Old Nov 4, 2010 | 09:40 PM
hillssol95's Avatar
is it blue smoke? because if its black your running rich from to big of injectors without being tuned correctly etc etc. If its white its coolent burning of etc.
Old Nov 4, 2010 | 09:48 PM
hillssol95's Avatar
oh i didnt read the rest of your last post yea it could be a turbo seal...good luck on the compression test!
Old Nov 4, 2010 | 09:49 PM
turbociv910's Avatar
do a comp and leak down and check shaft play. smell the exhaust, what it smell like?
Old Nov 4, 2010 | 10:03 PM
riceburner700's Avatar
valve stem seals?
Old Nov 5, 2010 | 01:30 AM
norcalB18's Avatar
Yeah i'm sure its oil because its blue smoke....Today i popped off the filter on my turbo and i see oil around the shaft and a pretty good amount that i'm sure shouldn't be there. So i think it might be the turbo guys. Gonna do compression check anyway because i started to scare myself a lil to much. Thanks people of HT
Old Nov 5, 2010 | 12:31 PM
hillssol95's Avatar
sounds like turbo for sure! at least its better than the bottom end. let us know the comp test results.
Old Nov 8, 2010 | 03:19 PM
Axix24's Avatar
had the same issue, swapped for a brand new turbo and everything is all good.. My brand new turbo failed out of the box..
Terrance
20
Jan 6, 2006 10:42 PM
KiNG $h!t
Jan 28, 2005 08:50 AM
90crxzc
Sep 1, 2003 06:28 PM
Austin
Feb 20, 2003 12:50 AM
QuickHonda
Sep 21, 2001 01:19 PM
