99 gsr boost!!
Old Nov 8, 2010 | 10:44 PM
b18cknight's Avatar
Icon2 99 gsr boost!!
im putting a 99 gsr into a 96 dx. whats the maximum recomended amount of boost for the gsr on all stock internals? i figure 7 or 8 psi............anyone?
Old Nov 9, 2010 | 04:25 AM
VTECROAR96typeR's Avatar
Default Re: 99 gsr boost!!
7psi would be good. You still should get a bigger fuel pump and injectors, aand get a tune..that way there is a better chance your motor wont blow so soon.
Old Nov 9, 2010 | 04:52 AM
Jimster480's Avatar
Well you need a tune first of all. Its not about the amount of boost as much as it is about the power. There are a few people making 400WHP on a stock internals GSR. But that is unlikely that you will be able to make that power. And if you plan to make any kind of power you will need what the guy above me said; Injectors, and a fuel pump.
Old Nov 9, 2010 | 05:42 AM
94GSRMR's Avatar
You "Figured 7 or 8psi"? how do you know 7 or 8 psi will or will not detonate? you dont... and ideal psi is not where you want to look. leave that up to your tuner, ask him questions while tuning.. thats the only thing i can think of that will get you an answer on psi.... GLWTuning.
Old Nov 9, 2010 | 06:07 AM
hybrid1990crx's Avatar
There is a lot of people making 350+++ hp on stock blocks. There is a thread right now where a guy made 600hp on a stock b16 on the dyno and dailyed it at mid 400 hp until the trans broke.
Old Nov 9, 2010 | 06:57 AM
Jimster480's Avatar
yea, its just usually not safe on pump gas. Since the GSR has high compression and small combustion chambers its prone to detonation.
Old Nov 9, 2010 | 06:59 AM
fin781's Avatar
Its all in the tune bro, 15 psi can kill your engine and so can 5 psi.
Find a good tuner, do it right 100%
Your stock gsr internals depending on mileage and wear/tear
should hold just fine if you dont drive like a maniac.
Remember, your bottom end isnt forged.
Old Nov 9, 2010 | 07:50 AM
AlexDphoto's Avatar
Old Nov 9, 2010 | 08:30 AM
reddcoupe's Avatar
as everyone said its all in the tune we had ours running safely at 14 psi
Old Nov 9, 2010 | 10:04 AM
DDTECH's Avatar
12 is a good "stock" psi to run gsr's @.
Old Nov 9, 2010 | 10:05 AM
boostedeg302's Avatar
uggghh....tune....whats that?? FAQs SECTION!!!
Old Nov 9, 2010 | 10:13 AM
AlexDphoto's Avatar
lol
Old Nov 9, 2010 | 11:52 AM
AlexDphoto's Avatar
high compression? I hardly call 10:1 high
Old Nov 9, 2010 | 11:54 AM
AlexDphoto's Avatar
how do you guys figure that 7 & 12 is a good psi?
Old Nov 9, 2010 | 12:45 PM
Glove's Avatar
i hear they say about 20 psi
Old Nov 9, 2010 | 02:08 PM
-BoostedVTEC-'s Avatar
lmao.. i am in the exact same position now! trying to find the perfect tuner for my stock GSRT setup! good luck brother
Old Nov 9, 2010 | 02:17 PM
AlexDphoto's Avatar
youre in florida, what about CFT? and isnt Vega in florida as well and Mase?
Old Nov 9, 2010 | 02:36 PM
DDTECH's Avatar
Cause, i know?
I've had a stock gsr running around on 15psi for about 2 years.. before it was tore down and built to run 30.
People run stupid low boost because they can't tune or anyone around can't.. if your tuning like normal and for every pound of boost you retard .75 on the ign your fine.. Hell i just did a tune on a customer who's got a bone stock b18a1, and he's running on 11 psi.. 1990 b18a1 motor.. 180k miles in a EG, egay turbo kit 50 trim.
I say 12 because thats the normal i'll shoot for unless a customer wants more.. if a customer comes to me, and ask whats best, i ask what its used for and what the setup contains.. b series sleeves are strong..even b20 sleeves are strong enough to hold about 14 psi bone stock.. its all in the tuning.. if i need to go more indepth, lemme know, blunder tuned a b20vtec bone stock on like 15 psi making like 430something whp.. and its still running, been a year or so..
here's a few from some friends of mine - ectuners
http://forum.ectune.com/viewtopic.ph...bf3e01dc748254
http://forum.ectune.com/viewtopic.ph...asc&highlight= (24psi stock sleeved...)
Its in the tuning my friend always will be.. bring me a gsr , bone stock and i'll put 14psi through it if you trust me and it'll last.. and run.
Old Nov 9, 2010 | 02:41 PM
AlexDphoto's Avatar
okay brah, ill go ahead and send 12lbs through my motor, the size of the turbo doesnt matter or anything
Old Nov 9, 2010 | 02:44 PM
DDTECH's Avatar
Now your talking like a ignorant person who just learned he was wrong.
We all know flowing 12 psi on a 60trim turbo is way different then flowing 12 psi on a 50trim.
Not to mention turbo hot / cold sides being different, there's alot of variables.. but in general, i was stating.
More then these silly single digit psi levels can be achieved with proper tuning and planning.
Old Nov 9, 2010 | 02:46 PM
DDTECH's Avatar
Stock k series have handled the upper teens quite well not to mention we've seen a stock k20a2 handle almost mid 30's before letting go..st00pid showed us that.
Old Nov 9, 2010 | 02:52 PM
AlexDphoto's Avatar
dont worry about it man, anything we could discuss would be beating a dead horse anyway.
No need to go through and reinvent the wheel right?
OP- the answer to your question is 12lbs because Allmotor tuned his customer on it.
Old Nov 9, 2010 | 02:56 PM
AlexDphoto's Avatar
Not trying to insult you personally or anything, but for as knowledgeable as you seem to be, you have to at least understand why this suggestion makes people simply shake their head right?
Just pointing it out is all.
Old Nov 9, 2010 | 03:02 PM
I say if your gonna ask that question then you got lots more research to do. My vote is 0 psi!
Old Nov 9, 2010 | 03:12 PM
DDTECH's Avatar
Oh, well ya, anyone who doesn't own a shop, or do this for a living, would shake their head because of all the mis information flowing around on the internet, not just here.. b20vtec.com is worst...way worst..
But ya, its a norm. I mean is it ideal for all setups, no, but if your going to throw such a vague questions out, i'ma give you a norm vague answer..
Some people like 7-10psi
I like staying around 10-12psi.
Some like to go radical. Just depends on how much you trust your tuner.. and ya.. i understand what your saying.
