BBK performance IM or Victor X
Old Nov 7, 2010 | 05:41 PM
93egSLEEPER's Avatar
Icon2 BBK performance IM or Victor X
Hey fellas I am looking for a little insight on these 2 products. I have seen numerous cars running the Victor X and making good numbers for higher boost setups and high revving motors. I have also been told about BBK performance who makes a IM and portmatched TB. They both look like nice products but I am looking for experience with it. I know the victor makes power 7-10k, but I wont be turning much past 9k with my setup so picking up midrange is a thought in my mind. Any opinions or experience?
They look almost identical in dimensions and how their built.
http://www.bbkperformance.com/produc...parts-398x.jpg
Thanks for the input
EDIT: I guess i should post my future goals. 500whp on pump gas and 600whp on c16 or 110 on a sc6262 turbo .82AR or a Garrett GT35R. Undecided yet. It will be a Benson sleeved 84mm GSR block fully built top to bottom.
Old Nov 7, 2010 | 06:49 PM
Default Re: BBK performance IM or Victor X
Bump....
Old Nov 7, 2010 | 07:08 PM
anavrin's Avatar
bump.........like to see some info on this myself considering i already have the victor x just waiting for my tune
Old Nov 7, 2010 | 07:31 PM
I know MarineSol was running it on his setup and was making 600+whp with it. I just want to see if anyone has comparisons or tuning/dyno experience on the 2.
Old Nov 7, 2010 | 07:37 PM
93Eh6pWr's Avatar
I dont know if its been changed, but i purchased a BBK throttle body a year and a half back and it didnt have a idle adjustment screw.
Old Nov 7, 2010 | 07:43 PM
2k.civic.si's Avatar
does not need one...just adjust the idle by the set screw for the rotor.
Old Nov 7, 2010 | 07:46 PM
DelSolMarine's Avatar
made 635whp with bbk intake manifold at 28psi... ran out of fuel
Old Nov 7, 2010 | 07:50 PM
93Eh6pWr's Avatar
I tried that... I piddled around with it for 4 months and the lowest I got my car to idle was around 1.2k, on a good day.
Old Nov 7, 2010 | 07:52 PM
you had a vacuum leak then.
Old Nov 7, 2010 | 07:53 PM
AHHHH almost got your SN right. haha looks like a nice piece man. Are you running their TB with it?
Old Nov 7, 2010 | 08:09 PM
93Eh6pWr's Avatar
Very possible that I did, but after using 2 cans of carb cleaner spraying all of the fittings and lines, I did not see any evidence that I did indeed have a vacuum leak.
Old Nov 8, 2010 | 03:56 AM
Zer0_SpeedWorks's Avatar
victorx gets my vote...
see sig with t3t67
only revving the motor at 9200
Old Nov 8, 2010 | 04:37 AM
i am running a 70mm RPM services throttle body...
635whp at 8500 rpms... the car started to lean out... if you keep like line straight on my dyno graph... it would have been in the 670whp range (theoretically) but at that point who cares...
however, this was with a FULL 3" exhaust vibrant resonator and borla mufflers
Old Nov 8, 2010 | 09:20 AM
see sig with t3t67
Do you know the bore of the Victor X on the TB opening?
Old Nov 8, 2010 | 09:29 AM
What injectors are you running? I plan on running 1200cc or 1400cc precisions or RC's. Im assuming there is still a performance loss with the exhaust on so 700whp open downpipe is feasable. Did you PNP your head? I'm going to run stock port for now and maybe later on have one ported out and see what happens.
Old Nov 8, 2010 | 10:08 AM
Dont quote me on this but I believe the VictorX is 68mm the bbk is actually 70mm inlet but from just looking at it the victorx looks like the plenum is larger than the bbk but idk
I am using 1000ID's at 90psi base pressure (fuel lab regular) with the walbro intank and bosch 044.... i dont know why it ran out of fuel... i had to get off the dyno do to time restraints... turning up the base pressure probably would have helped...
im pretty much done with the car... 435whp at 13psi keeps me happy and reliable....
Old Nov 8, 2010 | 02:14 PM
Thats the same thing I was looking at...the plenum. The victor does look slightly larger, and its round. The BBK is more square. The runners look like the same length for the most part, but the victor looks like it has a slightly larger diameter. I have looked and looked but have not found the volume/capacity of each one with a break down specifically in each area.
I know the 2mm on the TB wont make a noticable difference in this situation. I guess ill just do some reading here and there and everywhere and see what people have come up with. Hands down the VictorX has proven itself
Old Nov 8, 2010 | 02:19 PM
I did just find the VictorX TB port size and its 66mm from the factory, just as a reference.
Old Nov 8, 2010 | 02:29 PM
ahobbs made over 650 with the victorX IM
id just pick which one u can find for the best deal... i dont see that as that big of a restriction either way...
Old Nov 8, 2010 | 03:02 PM
i had to bore out my victor-x for the 70mm str thats on it.
Old Nov 8, 2010 | 04:41 PM
B23-Vtec's Avatar
My victor-x is ported to 80mm
Old Nov 8, 2010 | 06:11 PM
Thats the thing, I can get the BBK for $275 pretty much anywhere, and their TB for $250 but with not TPS. All the places selling their products have the same price. I have found the VictorX for as low at $240 all the way up to $400. With a Blox TB for $250 w/ the sensor is cheaper. I plan on going 68mm and running 2.5" charge piping. I dont see the need for 3"....unless someone can convince me differently.
Old Nov 8, 2010 | 06:24 PM
Professor_X's Avatar
I would really like to see a head to head comparison... could possibly increase bbk's sales
Old Nov 8, 2010 | 06:37 PM
This is what I am looking for. I just dont have the time/money/resources or I would do it myself.
Old Nov 9, 2010 | 09:21 AM
maybe... i can find one
if someone would like to donate one (i would mail it back) i will do a dyno test with my car on pump gas... i made 435whp at 13psi (wastegate)... i would be interested to see the diff....
