Wheel chirping; boost spike?
Old Oct 29, 2010 | 11:10 AM
kpjo4's Avatar
Default Wheel chirping; boost spike?
My wastegate's spring is at 7 pounds and everytime I go from 1st to 2nd I get mad wheel chirp and was wondering if the wheel chirp could be a factor in my boost spike, my last run I spiked to around 10-11psi during upshift.
Old Oct 29, 2010 | 06:03 PM
jfoster's Avatar
Default Re: Wheel chirping; boost spike?
What manifold and wastegate are you running?
Old Oct 30, 2010 | 02:31 AM
Tony the Tiger's Avatar
Yup, boost spike will create a sudden surge of torque... It will promote wheel spin if your traction limit has already been breached.
Old Oct 30, 2010 | 05:47 AM
boostedeg302's Avatar
A boosted car is gonna spin from 1st to 2nd. Be lucky your only getting chirp lol. My car is on ice skates at the top of 2nd lol
Old Oct 30, 2010 | 09:55 AM
kpjo4's Avatar
jfoster-Running a blox log style with a 38mm tial
tony the tiger-Well I would call it more of a wheel spin rather than wheel chirp,
boostedeg-I'm on a fairly medium sized turbo and with low boost so I actually have constant traction with some summer tires 195s, now when I shift I lose traction and my wheel spins and give me slight torque steer when I gain traction.
Old Oct 30, 2010 | 10:00 AM
PaddingtonBear's Avatar
195's? No wonder. Get some 205/50/15 Nitto Neogens, they are amazing street tires.
Old Oct 31, 2010 | 09:20 AM
kpjo4's Avatar
So the sudden loss of traction would not have to deal with any sort of boot spikes? I felt like since there was less load on the turbo it would spool faster and too fast for the WG to expel the gasses fast enough.
Old Oct 31, 2010 | 10:17 AM
jfoster's Avatar
I have a blox with a 38mm tial as well, running on a 10psi spring. My car breaks loose shifting into 2nd too, but as far as I know it never boosts over 10psi. Are you running an elbow to the WG? Where is your vacuum line ran to?
Old Oct 31, 2010 | 06:01 PM
kpjo4's Avatar
No elbow straight from manifold and my wastegate line is from the compressor housing
Old Nov 1, 2010 | 10:53 AM
dpetro1's Avatar
i highly doubt he would notice much if any difference between a 195 and 205. If anything a better compound would be a good idea (dunlop star spec's or bridgestone re11). also the 195's should have a slightly taller sidewall that should help with straight line traction as well.
Old Nov 7, 2010 | 04:08 PM
kpjo4's Avatar
I figured it out, my wastegate's vacuum line had a leak and I over boosted roughly around 1.5 bar and my car dies and interior fades, thank god I was on my street coming from applebees and now I have lots of blowby and I started the procedure of pulling the motor out for a overhaul. I'm assuming I blew my rings or ringlands.
Old Nov 7, 2010 | 04:13 PM
2k.civic.si's Avatar
Ouch....no one put a boost limit in the ecu program? when i tune cars i typically set the boost cut to 2-3 psi over what i tuned it for and set the fuel columns above the tuned ones to run rich.
Old Nov 7, 2010 | 04:45 PM
TheShodan's Avatar
Moderator
Yikes. Make sure you have good vacuum lines going to those areas. even a single tear could cause problems
99 Civic EX
Nov 19, 2007 07:54 PM
DAintegraGSR
Jul 19, 2005 12:42 PM
LostGsr
Apr 27, 2002 02:35 PM
pr0digy1
Nov 15, 2001 11:49 PM
