timing for boost quest
Old Nov 5, 2010 | 03:32 PM
grant97teg's Avatar
Default timing for boost quest
I have a 91 si with a y8, obd1. Now I dont have a problem timing my hondas in the past but this one confuses me. I bought a basemap for temp to get to tuner but the place I bought the chip from told me to run 12 deg timing. I borrowed a snap-on adj deg light. So normally they run at 17 deg which is the middle red hash mark on crank but when I set it to 12 deg I can only set it to the white tdc line which is fine but when I set it to 17 deg it only can be adj to the tdc mark also. So if I set the gun to zero deg will it show me the red hash? Then I set gun to 5deg? Motor warm and jumpered the service check connecter reved up to a couple grand. motor is all orig no milling and cam timing dead on
Old Nov 5, 2010 | 03:38 PM
grant97teg's Avatar
Default Re: timing for boost quest
The reason y I said set to 5 deg on the timing light is if I set the gun to 0 deg and that is act 17deg then will setting it to 5 deg mean 12 deg timing.
raverx3m
Apr 9, 2012 09:15 AM
jeffbrewer80
12
Sep 26, 2011 12:28 PM
civic j
Aug 17, 2007 08:10 AM
civictypenos
Oct 9, 2003 04:07 AM
dubnine
Sep 16, 2002 01:35 PM
