pcv problems plz help
Old Oct 25, 2010 | 07:55 PM
91teg6908's Avatar
Default pcv problems plz help
hey guys i have a d16y8 and car is smoking after full rebuild, so i got 400 miles on it and was going to change oil and pcv valve and there is no valve the black box and everything is gone. It looks like previous owner put a rubber freeze plug in the hole were the black box went, so the car is not venting and i think this could be some of my smoke problem. I was wondering if anyone had this problem or know how i could fix it so it vents right. The car is running 8 psi on new turbo so i am not wanting to drive it untill i get this pcv problem fixed if anyone know what i can do to fix this problem with out going to junk yard and finding a black box plz plz help me
Old Oct 26, 2010 | 07:39 AM
cevax's Avatar
Default Re: pcv problems plz help
The block not venting is most likely your problem, remove the plug and purchase a catch can. Route a vacuum line from the cold side of your turbo to the catch can then to the block. Do the same to the valve cover breather while your at it.
unspankable
Nov 4, 2013 02:20 PM
skaternak
May 13, 2012 11:17 PM
93 Eg Couper
Oct 4, 2010 01:24 AM
stevel
26
Jul 19, 2004 11:51 PM
pg_thao
May 21, 2002 03:52 PM
