Afr question
Old Oct 26, 2010 | 05:52 PM
spoon93's Avatar
Default Afr question
What should a stock ls turbo read on a aem euego wideband or what does urs read plz lmk asap
Old Oct 26, 2010 | 06:38 PM
ashb82's Avatar
Default Re: Afr question
11.5 afr
if you are 11s to 12s you will be ok i would not want to run a stock piston lean
Old Oct 26, 2010 | 06:40 PM
Spawne32's Avatar
Originally Posted by ashb82
11.5 afr
you only need to run 11.8 under boost, under vac you should be running 14.7
Old Oct 26, 2010 | 06:44 PM
turbociv910's Avatar
aem uego's i run 11.0 under full boost.
motec brand widebands i run 11.5 under full boost
Old Oct 26, 2010 | 06:45 PM
Spawne32's Avatar
any particular reason for the offset?
Old Oct 26, 2010 | 07:14 PM
spoon93's Avatar
Weird ok mine hits like 15.8 then I'll rev it and it will settle at 14.7 and slowly creep up the car is tuned on hondata s100 and ideas or tips thank u
Old Oct 26, 2010 | 07:19 PM
Spawne32's Avatar
a slow creep up is usually an indication of a sensor about to fail, mine did that at stop lights, used to slowly creep up to 17afr and back down again to 14, the sensor failed completely this morning.
Old Oct 26, 2010 | 07:26 PM
spoon93's Avatar
Wat sensor not the o2 right cause mines new maybe 20 miles on it
Old Oct 26, 2010 | 07:27 PM
Spawne32's Avatar
hmmm, odd, do you notice any difference in the way the engine runs? Are you simulating the factory o2 with the wideband, or are you running a factory o2 in conjunction with the wideband.
Old Oct 26, 2010 | 07:38 PM
spoon93's Avatar
Aem eugo wideband with the original Bosch sensor it's weird wen I installed it it was perfect but car has been sitting for week and a half and started reading different now do I maybe have to calibrate it idk
Old Oct 26, 2010 | 07:39 PM
Spawne32's Avatar
i would try a recalibration if there's no audible or visible change in the way the engine runs, typically when you start getting 15 or above you can start to hear the engine running lean or missing
Old Oct 26, 2010 | 07:48 PM
spoon93's Avatar
Ok sounds good thanks alot man for your help I appreciate it
Old Oct 26, 2010 | 07:50 PM
Spawne32's Avatar
just remember...afr isnt a single number, there is an entire map your computer uses to target different afr's across different conditions, you sound like your new at this based on the first post lol
Old Oct 26, 2010 | 07:58 PM
spoon93's Avatar
Lol u pinned that out I am deff a noob to this section ok here's one more the wire that goes to the ecu I did not connect I only did the ground and two power wires do I need to run it to my ecu
Old Oct 26, 2010 | 08:02 PM
Spawne32's Avatar
you still have your factory o2 sensor hooked up as normal correct?
Old Oct 26, 2010 | 08:06 PM
spoon93's Avatar
Oh no only the wideband with o2 it's located before the cat but there is no cat
jfoster's Avatar
I used to have a good example target AFR graph saved but it seems I lost it. IIRC I got it from Keebler's site back in the day. Anyway here are a couple decent examples from google img.
Old Oct 26, 2010 | 08:11 PM
Spawne32's Avatar
interesting, that raises questions about how your tune is setup
Old Oct 27, 2010 | 05:30 AM
Jeffro1265's Avatar
**** 11.8? im running lean as **** at 12.9-13.0. been boosted for about 3k miles on my 190k motor haha.
Old Oct 27, 2010 | 05:36 AM
Spawne32's Avatar
have you checked your plugs at all? thats a tad bit on the lean side
Old Oct 27, 2010 | 05:37 AM
ashb82's Avatar
how much boost
Old Oct 27, 2010 | 06:55 AM
Jeffro1265's Avatar
how much boost
57 trim@9psi. car runs like a freakin rocket LOL. trapped 112 through the 1/4,
Old Oct 27, 2010 | 07:33 AM
ashb82's Avatar
the car runs better in the 12 to 13 afr but the reason you tune to 11.5 is for cooling the cylinders and valves
Old Oct 27, 2010 | 08:38 AM
spoon93's Avatar
So 15.8 at idle is bad right I'm leaning out right also I jus put new plugs i'n today the old ones wer a lil black not chalky
Old Oct 27, 2010 | 08:54 AM
Spawne32's Avatar
thats a little too lean for idle, you want to be 14.7
