Wastegate spring 1,2 bar 17psi help
hi from germany
i will drive 1,2bar boost 17psi?
i have now 1.000 14.504 Large Blue 2.360
and 0.600 8.702 Small Blue 1.875 In SPRING
how much i must cut the small 0,6bar 8psi spring to get about 17psi 1,2bar boost???
cut the half 50% from the spring ore more? like 80%??
correct is two spring 0,4 bar spring and 0,8 bar to get 1,2 bar
can i use my methode????
infos
0.250 3.626 Small Yellow 1.875 In
0.400 5.802 Small Red 1.875 In *******************
0.500 7.252 Small Green 1.875 In
0.700 10.153 Large Yellow 2.360 In
0.800 11.603 Large Red 2.360 In *******************
0.900 13.053 Large Green 2.360 In
1.100 15.954 ** ( ex. Lg Yellow + Sm Red ) Small + Large
1.200 17.405 ** ( ex. Lg Red + Sm Red ) Small + Large
1.300 18.855 ** ( ex. Lg Green + Sm Red ) Small + Large
1.400 20.305 ** ( ex. Lg Blue + Sm Red ) Small + Large
1.500 21.756 ** ( ex. Lg Blue + Sm Green ) Small + Large
1.600 23.206 ** ( ex. Lg Blue + Sm Blue ) Small + Large
infos
Re: Wastegate spring 1,2 bar 17psi help
agreed, do no cut the springs. either get the correct springs or use one spring and a boost controller to achieve the desired pressure.
wrx'n you
12-15-2006 05:13 PM
turbo*s2k
10-14-2006 07:21 PM
turbo*s2k
Northern California (Sales)
12
10-13-2006 02:46 PM
DSRxSALSA
03-30-2004 06:58 AM
