Stoopid question...
Old Oct 26, 2010 | 01:30 PM
fatboi07's Avatar
Default Stoopid question...
Whats the piece called that goes here at the exhaust side flanged area of a turbo? Thanks
Old Oct 26, 2010 | 01:33 PM
Tootsie7944's Avatar
Default Re: Stoopid question...
Talking about the down pipe?
Old Oct 26, 2010 | 02:11 PM
fatboi07's Avatar
Is it the downpipe itself that has the 5 bolt flange on it? Or is there a middle piece the downpipe clamps/welds to?
Old Oct 26, 2010 | 02:31 PM
The downpipe will have a flange that bolts up to the turbo and then a flange on the other end that bolts to your exhaust.
Old Oct 26, 2010 | 04:05 PM
TheShodan's Avatar
Moderator
5-bolt "Ford style" turbine outlet.
Old Oct 26, 2010 | 05:17 PM
fatboi07's Avatar
You guys are so smart. God its good to be back on here. Thanks everyone.
Ps. So if i got the turbine outlet, id still need a downpipe to bolt to it right?
Old Oct 26, 2010 | 06:56 PM
Silva Bullit DC4's Avatar
Ps. So if i got the turbine flange, id still need a downpipe to bolt to it right?
Yup.
Question: what type of turbo manifold will you be using? And will you be running A/C with this particular setup? That will determine the direction your downpipe will be fabbed & mounted.
Old Oct 26, 2010 | 07:20 PM
fatboi07's Avatar
Its what i believe to be a mini-ram, and negative on ac. Hopefully my pic shows up, im only getting a red X box when i try to see the pic on here, but my browser has been giving me problems. Its one of the SSautocrome junk ones. A friend of mine wanted to go turbo cheap, and he wants me to do the install so I was like ok but I warn you lol.
Old Oct 27, 2010 | 05:37 AM
Jeffro1265's Avatar
good luck with that manifold dude. dont do it. spend an extra 40$ and get a cast manifold.
i bought one of those a while back and it kept literally blowing apart.
started here... and had it rewelded. then blew apart in a different spot. eventually i just threw it away after about 800 miles. ive found that almost ALL ebay metal parts are ****. they're cheap, weak stainless.
i then picked up some stainless steel wastegate elbows, and both flanges broke off the elbow within 150 miles.these:
Old Oct 28, 2010 | 10:51 AM
fatboi07's Avatar
Damn cheap ****. You get what you pay for though. Whats next step up from cast? Stainless done right?
Old Oct 29, 2010 | 05:48 AM
Jeffro1265's Avatar
basically. lovefab, revhard, ramhorn are some of the good ones.
Old Oct 29, 2010 | 04:04 PM
fatboi07's Avatar
Is ramhorn a brand, style, or both?
nokehockey20
May 30, 2016 01:51 PM
Blove1991
Apr 16, 2012 07:42 AM
W O T TWO
Dec 11, 2009 04:07 PM
MooreBoost
Oct 11, 2004 03:56 PM
streetlvlhatch
Feb 29, 2004 05:35 PM
