Very First Turbo Build
Old Nov 4, 2010 | 03:20 PM
John The G's Avatar
Default Very First Turbo Build
whats should i all do to my block to prepare it for the turbo.
Should i get the block guard
whats about sleeving?
im very new to this and i wanna do it right tiem isnt a factor besides need it tio save money
Old Nov 4, 2010 | 03:55 PM
Terrible One's Avatar
Default Re: Very First Turbo Build
what are your power goals? strictly drag car or daily driver?
Old Nov 4, 2010 | 03:57 PM
mikealike's Avatar
John,
theres a million combinations out there. first thing you need to do is to surf Honda tech, second, get your money up cause parts and labor isnt cheap, third set yourself a goal and follow thru to make this dream a reality.
Old Nov 4, 2010 | 07:04 PM
jfoster's Avatar
What motor are you turbocharging? And what are your power goals?
With this info you can plan out if your sleeves/internals are up to the job. You can also start planning what parts you want to run.
Basic typical parts list:
Fuel pump
injectors
manifold
turbo
wastegate
down pipe / exhaust
FMIC / piping / BOV
Tuning system / tuner
Other considerations = clutch, boost controller, guages, wide band, motor mounts, etc
Research is what you need.
Old Nov 4, 2010 | 07:18 PM
turbociv910's Avatar
forget injectors, fuel pump, just add boost!!!
... there is a search button you know
read this... the FAQ.
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Old Nov 4, 2010 | 07:27 PM
John The G's Avatar
yeah i new to the site and im jus figuring things out
my engine is a d16z6
its not my only vehical bnut i drive it often
im not sure but kinda power i can get out of the z6
heres the info on the kit im looking to get
T04E Turbo
.50 A/R Compressor, .63A/R Turbine
450HP Capable
T3 Flange to Manifold
5 Bolt Downpipe Flange
Oil Lube/Cool
3" Inlet Diameter & 2" Outlet Diameter
Bar and Plate Turbo Intercooler
27x7x2.5
2.5" outlet and inlet
150 to 130 Degree Temperature Drop
Stainless Steel Turbo Manifold forD-SIERES ENGINE
Made of High Grade T-304 Stainless Steel
Uses T3 Turbos and 35MM/38MM Wastegate Flanges
All nuts and bolts included
Direct Bolt on
38MM Wastegate
Utilized 35MM/38MM Flanges
V-Band top allows for quick changing of springs
Flanges and Gaskets are included
Designed to release gas efficiently
Better Control of Turbo
Direct Bolt on
Turbo Downpipe
Stainless Steel Design
Direct Bolt on (however requires rebending when used in conjunction with cast manifold)
Bolt On Intercooler Piping Kit
Stainless Steel T Bolt Clamps
silicone Hoses
Old Nov 4, 2010 | 07:39 PM
jfoster's Avatar
Here is over 500pgs of Dseries set ups -> https://honda-tech.com/forums/showth...t=single+slams
Billy ray
Dec 31, 2018 02:45 AM
sh!ft
Apr 18, 2010 06:53 AM
mcmmotorsports
11
Jan 20, 2007 09:16 PM
ludesrv
18
Dec 6, 2005 12:23 PM
Biqta
Jun 4, 2002 02:40 PM
