B20B Turbo Safety
Old Nov 17, 2010 | 09:51 AM
TuwboBuddy's Avatar
Default B20B Turbo Safety
Hey guys, just bought a '93 teg with a b20b in it and I plan on going turbo. I'll be aiming for around 300whp. I've done alot of searching and there is alot of debate about the reliability due to the thinner cylinder walls, but there are also a number of good running b20 turbos as well. My question is this...how much does it really matter if the cylinder walls are thinner as long as you're not detonating..?
Old Nov 17, 2010 | 11:09 AM
sp00led's Avatar
Default Re: B20B Turbo Safety
If the compression is good on the motor then go for it. Just don't be surprised when it fails after a while even with a good tune. If the tune isn't spot on then you are on borrowed time.
Old Nov 17, 2010 | 11:35 AM
rev-speed's Avatar
u have to have a good tune to make it live
here s one we just did(stock b20 block made 380whp on our dynojet)
and the guy ran it on nov 6 test n tune
its the white hatch first car on vid
http://www.youtube.com/watch?v=GnxT1tuhIjs
Old Nov 18, 2010 | 12:15 AM
TuwboBuddy's Avatar
Ok so basically as long as you run a good and/or conservative tune (shouldn't be detonating) the cylinder walls shouldn't (theoretically) be an issue? Do you guys think it's worth it to go B20/vtec then turbo, or just straight B20 turbo?
Old Nov 18, 2010 | 01:57 AM
rev-speed's Avatar
b20v
-straight b20 is hard to make power unless u add cams
lookout22
May 29, 2009 06:41 PM
ek9=]
Jun 28, 2008 04:23 PM
MUGENTYPER
May 7, 2005 04:44 PM
92VtecTeggy
Jul 4, 2003 01:56 PM
