Choosing the proper Map sensor for you Boost setup
Old Oct 27, 2010 | 04:22 PM
sakasaku's Avatar
Default Choosing the proper Map sensor for you Boost setup
Heres a Quick reference that i learned to aid in helping others in the future
Okay So a Bar is simply a Pressure measurement
A 1 bar Map sensor is what you would run on a N/A car But to stay within 1 Bar "Zone" and run right it has to stay below Stoich which it 14.7:1 which is 100% efficiency so on a N/A car you would not need anything more than a 1 bar Map sensor
Now this is were Boost comes in to play. when you boost a car it Becomes more efficient By Using exhaust gases to to force air in to the cylinder which intern increasing cylinder filling.
so that would be were you want to upgrade a From a 1 Bar map sensor
So you take The Amount Of boost you are going to run a and add it to Stoich
(EXAMPLE) 14.7 + 10 psi of boost = 24.7 PSIA (Pound per Square Inch Absolute)
Here a chart
1 Bar 14.7 PSIA
2 Bar 29.4 PSIA
3 Bar 44.1 PSIA
4 Bar 58.8 PSIA
5 Bar 73.5 PSIA
When yo add your amount of boost to Stoich lets say it when you added it all up it was 27 you would go with a 2 bar map sensor. Go with the next highest number from your total.
hope this all helps
And yes i understand you can grab a 5 bar map and be fine no matter how much boost you run just wanted to let everyone know how to decide which bar map sensor to use.
-Sakasaku
Old Oct 27, 2010 | 05:29 PM
unusual71's Avatar
Default Re: Choosing the proper Map sensor for you Boost setup
hahaha the reason its "stoich" has nothing to do with any of that bullshit its purely coincidence.
normal ambient air pressure is is right around 14.7 psi which also happens to be the ratio of fuel to air we want according to stoichiometry
Old Oct 27, 2010 | 05:58 PM
Turbo-LS's Avatar
as well as different elevations have different starting points in air density. the higher the elevation the less vacuum the engine will create as well as boost from lack of oxygn in the air.
That being said choosing a map sensor is a simple as how much boost you want to run. 14.7 plus the amount of boost with a little extra. stock map sensors are 1.7 bar or are good for about 10 psi boost.
Old Oct 27, 2010 | 07:55 PM
Silva Bullit DC4's Avatar
Edited...thanks for the correction, 808. Sorry, Justin
Old Oct 27, 2010 | 08:14 PM
Garage 808 Hatch's Avatar
1.7 bar absolute. or 10 psig.
Old Oct 28, 2010 | 08:35 AM
dpetro1's Avatar
agreed, OP has stoichiometry confused here. Stoich would be a 14.7:1 AFR.
also. 1 bar = 14.5 psi not 14.7 but hey who's counting
Old Oct 28, 2010 | 10:16 AM
unusual71's Avatar
yeah i always forget that the actual pressure here is always just a hair above 1 bar. I said around 14.7 to simplify my explanation
Old Oct 28, 2010 | 10:51 AM
Muckman's Avatar
Moderator in Chief
Hehe the stoich comment made me LOL. Good tech thread tho.
My contribution would be to choose the smallest "bar" MAP sensor that meets your needs with a little bit of room for growth. It will give you more resolution in the pressure ranges that you will be operating at. Another words dont get a 5bar if you plan to boost 10psi...
jdmdikk
Jun 20, 2009 02:42 PM
insaneconceptz
Mar 4, 2009 05:35 AM
00sitk
Apr 30, 2004 09:42 AM
roydogg
Jan 20, 2004 12:53 PM
Pro-Lude
Aug 29, 2001 04:26 AM
