D15b turbo engine how?
Old Oct 27, 2010 | 09:14 PM
pelacuas's Avatar
Default D15b turbo engine how?
I have a d15b vtec engine and I want to turbo it. I plan to run 5lbs of boost do I need to replace any parts or can I just install it like that?
Old Oct 27, 2010 | 09:28 PM
jyacoba2009's Avatar
Default Re: D15b turbo engine how?
you got a turbo kit? bigger injectors? chipped ecu? tune?
Old Oct 27, 2010 | 10:12 PM
eg6stroker's Avatar
just get some arp head bolts and some injectors and tune it
Old Oct 28, 2010 | 11:29 AM
LutherX's Avatar
you should be fine with everything stock. get a chipped p28 and tune it. the tune is key.
Old Oct 28, 2010 | 11:50 AM
joe111599's Avatar
Nah just slap the turbo on it and run 30 pounds. Stock injectors and everything. Everyones doing it.
Old Oct 28, 2010 | 01:41 PM
pelacuas's Avatar
I have chipped p28ecu would it be good to get bigger injectors? For5lbs of boost? Or can I run stock?- thanks
Old Oct 28, 2010 | 08:22 PM
jfoster's Avatar
You're going to have to use the search feature to educate yourself. This stuff has been covered 1000 times.
Here is over 500pgs of Dseries set ups -> https://honda-tech.com/forums/showth...t=single+slams
Old Oct 29, 2010 | 05:19 AM
Schister66's Avatar
Man U FTW
Do yourself a favour and read through the FAQ at the top of the page. It will answer a lot of the starter questions you have. If you have unanswered questions after doing your homework, then ask and we will be glad to push you in the right direction.
One piece of info to start you on your way: Dont set goals in terms of PSI as its an arbitrary measure...instead, set a power goal. Power creation can vary widely at X psi from one turbo to the next...or even one setup to the next (using the same turbo). If you search what boost actually is, you'll begin to understand why this is the way it is...
Old Nov 4, 2010 | 07:03 PM
pelacuas's Avatar
Do these things really work for increase in hpnthe electric one kinda makes a little sense to me
http://item.mobileweb.ebay.com/viewi...id=27884699177
http://item.mobileweb.ebay.com/viewi...id=85635622292
Old Nov 4, 2010 | 07:09 PM
jfoster's Avatar
No, that ***** a joke. I hope you noticed the thread I linked to and took note that no one was running that junk. There is also a FAQ section at the top of the forum that you should read.
Old Nov 4, 2010 | 07:14 PM
javie3's Avatar
just change injectors
Old Nov 4, 2010 | 07:25 PM
turbociv910's Avatar
ebay= good **** !!
Old Nov 5, 2010 | 10:25 AM
pelacuas's Avatar
ok so i already did some research and know what i need like turbo manifold piping intercooler etc... only thing im stuck on is that with more air you obviosly need more fuel but im not sure how to get it? will bigger injectors work? how can i do it?
Old Nov 5, 2010 | 10:42 AM
jfoster's Avatar
You'll need a higher flow fuel pump, like a walbro 255 intank, larger injectors such as 450cc DSM injectors, tuning software such as crome/uberdata/neptune/uberdata/etc, a wide band 02, and the knowledge of how to tune with the tuning software (either learned or purchased from a pro tuner).
Have you read the Single Slams thread at all? Like I said there's over 500pgs of set ups and most included this info. For example:
Originally Posted by rextec
-d16z6 .20 overbore stock sleeves
-cp 9.1.1 pistons
-eagle rods
-acl bearings
-arp studs
-tial 38mm wg
-bored stock tb
-stock head
-zex 59300 cam
-rc 500cc injectors
-255 lph walbro inline
-thermal IM gasket
-BMC elf mani
-precision gt3251e turbo
-"RFL" bov
-crome
-zeitronix wb
-3.5 bar map
Old Nov 5, 2010 | 01:47 PM
pelacuas's Avatar
I've read the single slams thread I just wasn't sure how to exactly increase the fuel intake _ thanks
beginmyhonda
11
Dec 19, 2011 04:21 PM
vtak2nr
Engine Management and Tuning
Nov 27, 2011 06:02 AM
Ek9 Kid
May 31, 2010 07:59 AM
VTteg
May 7, 2006 06:19 AM
darkirony
Sep 28, 2004 05:55 PM
