b16 turbo help
Old Nov 4, 2010 | 03:12 PM
H22*CiViC's Avatar
Default b16 turbo help
Which turbo should i run with this set up? Planning on running 20 psi high and about 14 low for daily driving.
-b16a2
-gsr tranny
-kevlar cluth with pressure plate
-walboro fuel pump
-eagle rods
-arp harware
-cp 9:1 pistions
-aem cam gears
-denso 650 cc injectors
-golden eagle block guard
-blanced and mirco polished crank
-ported head work
-skunk2 swirl coated valves
-skunk2 springs/retainers
-skunk2 intake manifold
-skunk2 stage 2 turbo cams
-skunk2 68mm throttle body
-bm fpr w/guage
-custom 3" down pipe with exhaust
-tial wastegate
-tial bov
-lovefab manifold
-gm 3 bar map sensor
-presion 60-1 turbo
-Hondata S300
Old Nov 4, 2010 | 03:55 PM
Terrible One's Avatar
Default Re: b16 turbo help
what are your power goals?
Old Nov 4, 2010 | 07:17 PM
jfoster's Avatar
You might also check out what other people are using on their B16 set ups, many posted here -> https://honda-tech.com/forums/showth...&highlight=b16
Old Nov 4, 2010 | 08:08 PM
hybrid1990crx's Avatar
From your mod list it looks like you already picked a 60-1. Now the question is what a/r? With that engine set up you should be good for about 500whp.
Old Nov 4, 2010 | 08:49 PM
H22*CiViC's Avatar
I want to get about 400-500 hp but the turbo im running right now takes too long to spool around, 4500 is when it spools. Its an older persion turbo non billet one.
Old Nov 4, 2010 | 08:59 PM
TheShodan's Avatar
Moderator
Do you want this power on pump or race gas? what's your budget to spend on a turbocharger?
Old Nov 5, 2010 | 10:42 AM
H22*CiViC's Avatar
Im thinking of running e85. Im not really budgeting on the turbo just want quick spool with a good amount of horse power output.
MYEMWON
Mar 22, 2016 10:54 AM
hybrid3211
Mar 3, 2011 07:33 PM
egalldayNF
Jul 25, 2010 09:10 PM
98couperc4
Apr 19, 2010 05:39 AM
kryptonight
Sep 6, 2008 06:53 PM
