Quick sparkplug gap question
Old Nov 14, 2010 | 12:06 PM
alacard's Avatar
Default Quick sparkplug gap question
The car is a 98 hatch
engine is a stock b18c1
turbo at about 10 psi tuned on hondata
I've read that ngk bkr7e plugs are the way to go. (someone correct me if I'm misinformed) Now I just need to know what to gap them at. I've read that the common rule is to gap them smaller for the more power you make. I also read that the standard range for a turbo honda is between .28 to .35 or something like that. How do you really know what to gap it at exactly?
Old Nov 14, 2010 | 12:48 PM
94GSRMR's Avatar
Default Re: Quick sparkplug gap question
first go buy a spark plug gapper tool, they are about $1.33 at a autoparts store. take them out one by and check the gap in between the little hook itll tell what they are gapped to. hope this helps.
Old Nov 14, 2010 | 12:53 PM
AlexDphoto's Avatar
from what I understand running a .025-.028 or even .030 is the ideal gap for turbo hondas.
I run mine at .025.
Just go out and buy a gap tool, super cheap, and easy to do.
Old Nov 14, 2010 | 01:53 PM
94GSRMR's Avatar
Alex you are so helpful i run mines gapped at .24
Old Nov 14, 2010 | 02:08 PM
runsfromdacops's Avatar
i run my plugs at .18
Old Nov 14, 2010 | 02:11 PM
AlexDphoto's Avatar
I just run the gap my tuner tells me lol. They use .025 on all their turbocharged honda applications.
No issues with it yet.
Old Nov 14, 2010 | 02:44 PM
alacard's Avatar
Sorry, I was a little misleading with my question. I know HOW to gap, just not what I should gap it to. I guess I could give my tuner a call.
Old Nov 14, 2010 | 03:04 PM
AlexDphoto's Avatar
I run mine at .025.
anything within this range should be fine. commonly, ive seen people have their gaps set in the 20's. do a quick search and find out.
Old Nov 14, 2010 | 04:51 PM
dpetro1's Avatar
A quick peek at the forum FAQ would have answered this question for you:
https://honda-tech.com/forums/forced-induction-16/spark-plug-gap-877602/
always look there before searching or creating a new thread.
Old Nov 15, 2010 | 01:48 PM
Turbo-LS's Avatar
dont knwo the turbo but its probably a basic setup, .030-.028 should be a good gap though.
Old Nov 15, 2010 | 02:34 PM
alacard's Avatar
https://honda-tech.com/forums/showthread.php?t=877602
If you read my original post, I referenced a lot of information I HAD ALREADY found. So I clearly had searched already, but had come up with a wide range of gaps that I wanted to get more clarity on. Thanks for the link.
Thanks for all of the responses.
Old Nov 16, 2010 | 06:12 AM
dpetro1's Avatar
thats the point of an FAQ section though. The question has been asked so many times that the moderators put the "best" answer into the FAQ so that way you dont have to search all over or be concerned with finding conflicting information.
i was nice enough to link you to the correct answer and you accuse me of not reading your orignal post. gimme a break. .028"-.035" is not a wide range. if you had really searched you would have found that you can start high and gap down as needed. NGK suggests reducing gap by .004" per 50hp.
its all good though, ill be sure to just say SEARCH or link you to lmgtfy next time.
EDIT: for fun i googled "turbo honda spark plug gap" and what do you know...the very first result is the link i posted above.
Old Nov 16, 2010 | 01:18 PM
blackeg's Avatar
honestly dont get those cheap spark plug gapper tools...get a nice set of feeler gauges. plus you can use it for other things as well.
bkr7e's (stock 4644) are the way to go, your setup should likely be gapped around .028
TravisBiggie
Jul 23, 2012 03:25 PM
Hazymix
Apr 13, 2007 04:29 PM
elpiar
Oct 6, 2005 07:22 PM
TEG777
Oct 3, 2005 04:43 PM
01ITR#700
Feb 16, 2003 12:50 PM
