What rods to use?
Old Feb 13, 2012 | 07:02 AM
kenizzle's Avatar
Default What rods to use?
So I was planning on using some Eagle Hbeam rods for my d16 turbo build. But I see that the block needs to be notched. Are there any forged rods that I can use that I wont have to modify anything to use? If they can handle 400hp that would be plenty. This is my dd just want it to push like 250-300 so I can have a little fun with it.
Old Feb 13, 2012 | 07:03 AM
kenizzle's Avatar
Default Re: What rods to use?
Also wanna try and keep them under like 350 dollars as its kinda a budget build.
Old Feb 13, 2012 | 08:41 AM
kenizzle's Avatar
Anyone??? If theres no way Id like to know so I can start searching for someone to do the notchs for me.
Old Feb 13, 2012 | 09:44 AM
tron_'s Avatar
10 Year Member
You could use some shot peened LS rods that should hold up to your HP goal. With pretty much any H or I beam rod for the d15/d16 (FJ, eagle, bisimoto, etc) you will need to notch the block and the girdle.
Notching really isnt tough at all man, just mark out the portions that need to be notched and slowly take away the material with a grinder. Not a big deal at all!
Old Feb 13, 2012 | 09:47 AM
tron_'s Avatar
10 Year Member
You would also need to get the LS rods shaved to fit the d16 crank and get a correctly sized wrist pin since the pin diameter on the LS rods is 2mm (i think) larger than the d16 rods.
Old Feb 13, 2012 | 10:56 AM
stackedhouse's Avatar
I thought the point of fjs I beam was to not have to notch it
Old Feb 13, 2012 | 11:11 AM
tron_'s Avatar
10 Year Member
Nah, I'm running them in my d16 and I had to notch them. The point is theyre a little longer than standard length rods so, when paired with vitara pistons, the piston sits level with the top of the deck. With standard length rods the vitaras sit a little under the deck causing very low compression.
Not to say you cant run a vitara on a stock length rod but thats a discussion for another thread
Old Feb 13, 2012 | 05:55 PM
kenizzle's Avatar
Well its looking like Ill just have to find someone who can do this for me. Really wanna be sure my build is strong and reliable. Just dont trust running boost on my 150k zc bottom end.
Old Feb 13, 2012 | 07:21 PM
SovXietday's Avatar
It's really not hard, a little bit of time with a dremel and a nice aluminum bit and it will fit. Just take your time, it's not a precise kind of thing. Smooth out all of your edges and test fit everything to make sure it all fits before you bolt it together permanently. Really easy.
Old Feb 14, 2012 | 05:50 AM
kenizzle's Avatar
Guess its time to find a loaner car for a week.
Old Feb 14, 2012 | 05:54 AM
kenizzle's Avatar
Also my friend who would be doing the work is leary that it will cause issues with the block. Doesnt think its right to be grinding in there.
Old Feb 14, 2012 | 06:04 AM
tron_'s Avatar
10 Year Member
Head on over to d-series.org. Pretty much everyone who is running a d15/d16 with forged rods has to notch the block and/or girdle.
Old Feb 14, 2012 | 02:14 PM
kenizzle's Avatar
Thanks for the info guys. Time to buy a second block to do this work to then will put in new bottom end parts.
boostedb16EG
Oct 26, 2012 12:00 PM
Rease3
May 28, 2009 10:57 AM
supratin
Sep 2, 2007 09:59 AM
RACEPAK
Jul 14, 2007 06:49 PM
Boricuanology
Dec 25, 2006 02:05 PM
