b16 sounds like a subaru
Old Jan 28, 2012 | 09:10 AM
EGscrapyard's Avatar
Default b16 sounds like a subaru
I have a boosted b16 started it up the other day and it sounds like an sti, lacks power, and stumbles under hard acceleration. Replaced cap, rotor, plugs, wires, and fuel filter. No codes being thrown. Just adjusted my valves. Did a compression test, 178 187 189 182. So compression is still. Good. What could it be?
Old Jan 28, 2012 | 09:13 AM
grumblemarc's Avatar
The Grumpiest
Default Re: b16 sounds like a subaru
WHat are your AFRs looking like? WHat EMS are you running?
Old Jan 28, 2012 | 09:16 AM
I just got it tuned on crome. I have a narrowband afr gauge that says its always in the right area.
Old Jan 28, 2012 | 09:17 AM
The Grumpiest
Narrowbands are useless. And it sounds like you're running on a basemap, not a tune. WHen was the last tuneup? What plugs are you running?
Old Jan 28, 2012 | 09:20 AM
Its tuned. Just did the tune up yesterday. Checked cam timing, but im not just on a basemap its all tuned for my set up.
Old Jan 28, 2012 | 09:21 AM
OOh and ngk bre7-11 gapped to .030
Old Jan 28, 2012 | 09:24 AM
The Grumpiest
What do you consider a tuneup? Take it back to whomever did the tune. I would have said you're possibly misfiring but you're not even throwing CELs.
Last thing I got is to check the plug wires, cap & rotor.
Old Jan 28, 2012 | 10:30 AM
TealCivic115's Avatar
Go to your local auto parts store and buy a bottle of HEET fuel antifreeze. My **** was doing the same exact thing with no CEL's either. After I poured it in the gas tank it made a 100% difference. I also did a fuel system flush at my shop and it cleaned out so much nasty gunk built up in the stock fuel system/lines. Let me know how that works.
-Will
Old Jan 28, 2012 | 10:31 AM
I jjust got a brand new plugs, wires, cap and rotor.
Old Jan 28, 2012 | 10:46 AM
I consider a tuneup plugs, wires, cap, rotor. I also replaced my fuel filter and had an injector service done. Checked my cam timing. Adjusted valves. Etc.
Old Feb 1, 2012 | 06:38 PM
sorry for the late reply. how is it running now? same issue?
Old Feb 1, 2012 | 07:39 PM
Red_Army's Avatar
start with a wideband AFR first. not sure how you got it tuned with a narrow. unless you had them take it out for a wideband just to throw the whole idea away.
Old Feb 1, 2012 | 07:55 PM
egsleepercivic's Avatar
was it doing it before you replaced the cap wires plugs and fuel filter ? did you wash the engine bay at the same time ?
Old Feb 1, 2012 | 11:51 PM
jbpnoman's Avatar
Get a wideband in there ASAP. It's the easiest way to keep an eye on the health of your motor, and arguably the most important gauge you'll have in your cluster. It might also help us figure out what's wrong.
Old Feb 2, 2012 | 03:27 PM
ek4_b16a's Avatar
Mines n/a, but I once experienced that. LOL. Funny thing was I had one fuel injector clip unplugged and sounded like that. No check engine light, lack of power, but the beautiful sound of a Subaru. Check your plugs. GL. Hope all is well.
Old Feb 2, 2012 | 03:32 PM
hmonguy918's Avatar
hey same thing happen to mines but i lost compression in one clyinder.. wat can that be?
compression =0
Old Feb 2, 2012 | 04:52 PM
Steezer's Avatar
im just throwing this out there but it could be your Catalytic Converter. I had the exact same problem, lack of power, stumbling acceleration, Vtec engages but i dont go anywhere. I replaced all my spark plugs and wires with no solution. So I just replaced mine tonight and im very surprised that the converter was my problem. Also not to long ago someone on here had the exact same problem and said "It sounds like a Subaru" too. Needless to say it was a $hit converter he had. If you have the original converter from the factory this could very well be your problem.
Old Feb 2, 2012 | 06:14 PM
DirtyDA9's Avatar
If you are using a narrowband, the car isn't tuned. Unless your tuner is good at blindly tuning.
Old Feb 18, 2012 | 10:06 AM
I got tuned on a wide band. I'm not an idiot. I know how to Turbo a car. Now anyways. I'm thinking it could be bad dizzy contacts or my main relay cracked and fried an injector. But ill check the things you all just listed. My afr's are all spot on. My buddy has a wide band. Its not hard to through one in real quick and check things. I would never get a car tuned on a narrow band.
Old Feb 18, 2012 | 10:36 AM
94EG8's Avatar
Seagull Management
Moved to forced induction.
Old Feb 18, 2012 | 11:04 AM
decon's Avatar
hey guys i dont know if this will help or not, but gonna add it. wrx's and sti's sound the way they do because of the unequal length header they have from the factory. I had a wrx for almost 5 years, how i know.
Old Feb 18, 2012 | 11:16 AM
92redhatch's Avatar
I had my b16 motor like 6 years ago sound like a Subaru. I broke a piece off a valve. I was running nitrous and spraying at the top of 4th gear at like 9000rpm. That's the only experience I have with a b16 sounding like a subaru. I hope for you sake its something else.
Old Feb 18, 2012 | 11:46 AM
Schister66's Avatar
Man U FTW
Whats the exhaust setup on the car? If you're running a cat and were using a narrowband to tune, you could have plugged it up and will continue to run rich.
Old Feb 20, 2012 | 05:20 AM
I didn't tune on a narrow band. How many times do I have to say that? Lol. And yes it has a cat I'm going to get 3 in. Straight pipe put on this week
Old Feb 20, 2012 | 05:26 AM
DDTECH's Avatar
A cyl is not firing.. whether a plug is fouled or something..
