Fuel pump/injector planning web app
Old Jan 27, 2012 | 04:33 PM
hybrdthry911's Avatar
Default Fuel pump/injector planning web app
Looking for some feedback on this app I created. Used some pretty common calculations. Just used for a quick reference on power and pump/injector capacities.
http://webpages.charter.net/hybrdthr...mp_web_app.htm
Old Jan 28, 2012 | 07:41 AM
DelSolMarine's Avatar
Default Re: Fuel pump/injector planning web app
I love it! The A/F changes did not work though and an E85 converter would be awesome!
Old Jan 28, 2012 | 09:34 AM
Thanks for the feedback. For e85 just change the air fuel to 7.9:1 it will adjust the demands on the chart. Changing the BSFC for your fuel would change the injector size requirements.
Old Jan 28, 2012 | 11:01 AM
Turbo-LS's Avatar
BSFC isnt making any adjustments, everything else is working and i like it! Any chance you can set it up to do tweo pump combo's meaning a walbro in tank and bosch inline running together. either way great app !
Old Jan 28, 2012 | 03:58 PM
Fixed it and removed the entry so it just estimates the bsfc for you and you can just put the air fuel ratio in. ~7.9-8 for e85. I would love to add the functionality of the 2 different combo pumps but I don't know what the flow rates on those combos would be. If its a simple as just adding them or even a percentage of it then it wouldn't be a problem. Has anyone flow tested that combination yet?
Old Jan 28, 2012 | 04:04 PM
mines13's Avatar
Would it be possible to add the 190lph walbro high pressure model?
Old Jan 28, 2012 | 04:05 PM
Originally Posted by mines13
Would it be possible to add the 190lph walbro high pressure?
I could if you have a link to the flow rates.
Old Jan 28, 2012 | 04:08 PM
mines13's Avatar
http://www.autoperformanceengineerin...l/fpspecs.html
This seems like a good resource. If the other data lines up with what you have collected its likely trustworthy.
Old Jan 28, 2012 | 04:45 PM
Desir Performance's Avatar
Great App, what about staged injection with different size primary and secondaries. Also what about some Weldon pumps?
Old Jan 28, 2012 | 04:51 PM
Added.
Old Jan 28, 2012 | 04:54 PM
mines13's Avatar
awesome resource. I think I'm gonna be ok. 350hp (optimistic) 43.5 base fp with ID725cc.
Old Jan 28, 2012 | 06:43 PM
This thing is pretty accurate! You should add in fuel line sizes! lol
Old Jan 28, 2012 | 06:55 PM
sanman000719's Avatar
add the awromotive pro-series pump also
pump information
http://aeromotiveinc.com/products-pa...ies-fuel-pump/
Old Jan 29, 2012 | 01:32 AM
Added a bunch of weldon and aeromotive pumps as well as functionality to check multiple pumps at the same time. I also added functionality for fuel pump voltage changes, this is only an estimate based on common calculations.
I used most of my information from kinsler. I don't trust aeromotives figures. The graphs never seemed to add up. I used the kinsler part 10262 for the aero PRO and 10261 for the eliminator. Can anyone verify that these are in fact the right flow values? Kinsler doesn't say which pump is which. Link is below check page 125.
http://www.kinsler.com/Cat_32_Whole_...9_WholeSec.pdf
Keep the feedback coming, I appreciate the comments so far. Im going to add individual pump counts tomorrow so you can compare say 2 walbro 255's vs 1 aero pro.
Old Jan 29, 2012 | 10:25 AM
I added control for Vacuum/Boost Referenced pressure regulators vs Non Referenced FPR. I also added control for quantity for each individual pump so you can compare 2x pumps vs single or other multiple pumps.
Old Jan 30, 2012 | 04:32 AM
em_at_kfi's Avatar
The 10265 is the A1000, the 10261 is the Eliminator, the 10262 is the Pro Series.
IceySC
Dec 26, 2009 04:40 PM
jdm206
Aug 29, 2007 04:24 AM
Screamer
Jun 18, 2003 09:17 AM
01ITR#700
Mar 31, 2003 08:34 AM
GSR_Hacker
Jul 8, 2002 06:50 PM
