quick question, can i use this hose end on my -3 AN feed line?
Old 01-15-2012, 11:32 AM
TB123's Avatar
Default quick question, can i use this hose end on my -3 AN feed line?
I stripped the threads on my turbo feed line and would like to replace the hose end rather than the entire line.
I am looking at this hose end:
http://www.summitracing.com/parts/SUM-220140/
Can anyone tell me if this is the type of AN hose end that you "push on" (does not require a crimping tool). Also, I believe the threads on the male fitting on my turbo are 3/16". This 3 AN hose end should be compatible, correct?
Old 01-15-2012, 07:47 PM
Sprockets's Avatar
Default Re: quick question, can i use this hose end on my -3 AN feed line?
It's not a socketless "push on" type hose end, but you also don't need a crimping tool for that fitting. Socketless hose ends don't work with braided hose. This link should help with your other question:
http://www.brennaninc.com/documents/...hreadChart.pdf
Old 01-15-2012, 08:16 PM
TB123's Avatar
Does it install the same way as this?
http://www.youtube.com/watch?v=KwmvRWuAwno
Old 01-15-2012, 11:20 PM
Sprockets's Avatar
No, it's Teflon hose. Like this...
http://www.youtube.com/watch?feature...&v=3tjRsbSDA48
Dunc
06-18-2006 09:30 PM
lopey
05-04-2004 09:07 PM
ntegls
04-19-2003 09:26 AM
Sonny
02-09-2003 09:40 PM
Quick Reply: quick question, can i use this hose end on my -3 AN feed line?
