Whats a good brand
Whats a good brand
to go with to build my H2b setup. I want to put a turbo on it so What all do I need besides the turbo stuff. What would I need to do internal of the motor?
Ek Forever y0!
Re: Whats a good brand
You can leave the block alone if you want. As long as you keep it mild. If you're mechanically inclined you should probably install a block guard and some beefy headgasket, ARP head studs, etc.
Just reinforce what you can. And go to town. I've heard/seen people make 400whp on stock block h22's.
I have already looked into the g23 and it has to much things that HAVE to be done in order to make it work...Plus it is cheaper the way I want to go...
The Grumpiest
I think you got your answer, which you could have got by searching prior to posting. The sleeves and ringlands will go first but no one really knows your HP goal to see if those items need anything done to them in the first place.
The Grumpiest
C'mon man. Do some research. This aint it. I could tell you something and how would you know I was accurate? Go check the Hybrid forums and see what others have used successfully.
https://honda-tech.com/forums/hybrid-engine-swaps-18/
Ek Forever y0!
Most people who know what they are doing use half a dozen brands.
porofek
03-08-2019 01:43 PM
