Turbonetics Deltagate Mark II opinions
Old 01-12-2012, 12:48 PM
Mr. Winky's Avatar
Default Turbonetics Deltagate Mark II opinions
I came across an older Deltagate Mark II wastegate in almost new condition. I picked it up for practically nothing. I have heard mixed issues with this particular model and was wondering pros and cons.
I soon realized that there are zero rebuild kits for this thing so I took it apart to check the internals and to my surprise..it is in extremely good shape. The diaphragm is perfect and everything is in tip-top shape. I plan to use it on my current build with the current (I think) 7 lb. Spring.
Should I use it or ditch it and buy a trial??
Any upgrades I can do to it to make it last longer under normal driving conditions? Any help, input, ideas would be greatly appreciated.
Old 01-12-2012, 02:35 PM
Turbo-LS's Avatar
Default Re: Turbonetics Deltagate Mark II opinions
Boost creep galore! Lol
Old 01-12-2012, 02:59 PM
turbohatch96y7's Avatar
I had the old delta gate before and it did leak. So I put a compressor to it about 5 psi.
Found leaks from the screws that mount the diaphragm to the exhaust outlet. All I did was put gasket maker on the screws than I installed the screws and never had a problem. Leak test it
Old 01-12-2012, 04:00 PM
Mr. Winky's Avatar
Pressure test from the lower fitting or upper? Or both?
Old 01-12-2012, 08:31 PM
Both. Make sure it holds pressure and moves in and out right and your good.
Old 01-12-2012, 09:28 PM
MR.johnson's Avatar
yep. lol. seenit!
Old 01-13-2012, 02:40 PM
vwbased's Avatar
have a nice day
Old 01-13-2012, 04:54 PM
MR.johnson's Avatar
no. they suck.
Old 01-13-2012, 06:08 PM
CO_RaceFab's Avatar
Creep is not from the gate it comes from your crappy manifold design... Wastegates are not the most technical thing on earth its a valve a spring and a housing... Make sure it holds pressure and your good.
Old 01-14-2012, 07:20 AM
nsxmatt's Avatar
I had a couple of them, worked great and had no problems. Like was said, a wastegate is a simple part. As long as it doesn't leak you'll be fine. You don't have to have the latest fad of the week on HT to have a reliable inexpensive setup.
TnC
10-12-2008 11:32 AM
PB400Whp
08-21-2005 02:27 PM
b18cEF9
07-24-2005 01:18 AM
crazyimport
07-14-2004 06:08 PM
swlabhot
11-10-2003 02:04 PM
Quick Reply: Turbonetics Deltagate Mark II opinions
