eagle bearing clearance?
Old Feb 9, 2012 | 02:58 PM
mike703's Avatar
Default eagle bearing clearance?
What should i set the bearing clearance to on a gsr crank with eagle h beams...im thinking within oem specs but could someone clarify
Old Feb 9, 2012 | 04:15 PM
mike703's Avatar
Default Re: eagle bearing clearance?
really 101 views and no response...am i just that dumb?
Old Feb 9, 2012 | 04:27 PM
blackeg's Avatar
On the looser side of the oem specs. I wouldn't accept anything less than. 0015.
Old Feb 9, 2012 | 04:37 PM
mike703's Avatar
so you wouldnt want them any tighter is what youre saying...im sorry for the noobishness...i just need to know what to tell the machine shop because im not assembling the bottom end myself. i trust myself with everything except bearings. mainly because ive never done them by myself before.
Old Feb 9, 2012 | 04:54 PM
Whiterice-gsr's Avatar
since i just talked to u about your setup and know what your looking for 0015 i think is abit tight u may want 0018 but ive heard guys on here build them to 0022 but thats for some serious power. ive also heard guys sa they had issues with excessive wear on certain bearings at 0015, i think if u post some numbers you'll get alot more responses and advice.
Old Feb 9, 2012 | 06:19 PM
mike703's Avatar
^^^^^what numbers should i post?
Old Feb 9, 2012 | 06:22 PM
Spawne32's Avatar
have you ever seen the inside of an engine before?
Old Feb 9, 2012 | 06:30 PM
blackeg's Avatar
well yea, on facebook and stuff. there is another good thread going currently about bearing tolerances. check it out
Old Feb 10, 2012 | 02:32 PM
heres a link to that other thread its on the first page though.
https://honda-tech.com/forums/forced-induction-16/engine-builders-oil-clearances-too-tight-3025252/
Old Feb 10, 2012 | 06:06 PM
mike703's Avatar
Thanks
GruvyTune
Engine Machining & Assembly
14
May 22, 2020 09:28 PM
karmaworks199
Oct 15, 2016 02:13 PM
AFAccord
Aug 3, 2015 03:26 AM
yellowturbo
Dec 18, 2003 08:23 AM
