Oil Line Help
Old Feb 10, 2012 | 03:41 AM
ÁrniMkv's Avatar
Default Oil Line Help
Hello
i'm working on getting every thing ordered for my ek4
but i still have a few questions
i'm gonna install a oil cooler and i will be using a sandwich for that but the feed line for the turbo where should i get the oil for the feed line? if the cooler takes both plugs in the sandwich?
or is the sandwich only 2 outputs?
Old Feb 10, 2012 | 03:45 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Oil Line Help
Yes - if you buy a 2 outlet sandwich. They also sell ones with 3 and even 4 outlets... maybe more.
Old Feb 10, 2012 | 07:02 AM
tron_'s Avatar
10 Year Member
You might not want to use a sandwich plate for the feed line because it is unfiltered oil that would be fed to the turbo. I did this on a fresh build and messed my turbo up pretty bad.
Granted if this is a higher mileage motor you might be okay because there wont be machining scraps everywhere but I would rather just use a brass T fitting on the back of the block (the oil pressure sensor port) like this:
I did something a little different, I made an oil distribution block since I had a temperature sender too and was worried the vibrations would make the brass fitting crack. Heres a quick sketch of what I did:
Dre90
Apr 20, 2010 04:11 PM
goldex420
Apr 6, 2008 05:23 PM
jdm2ner
May 15, 2005 12:52 AM
Prelude91siT
Jan 19, 2004 06:24 AM
slingshotsi
Sep 9, 2001 06:11 PM
