LSv Turbo - No oil on dipstick
Old 01-27-2012, 06:44 PM
diviznrider's Avatar
Default LSv Turbo - No oil on dipstick
no oil on dipstick after driving home from tune on my turbo ls vtec. figured it was low and did an oil change. about 4 quarts or more was drained and i put in about 4.2 quarts back in but it still shows nothing on my dipstick. do all my oil lines for turbo and lsvtec factor into that much more oil i need to pour in? i dont want to overfill it.
Old 01-27-2012, 06:55 PM
Slacker93eg's Avatar
Default Re: LSv Turbo - No oil on dipstick
Stupid question, but, is the dipstick going all the way into the tube?
Old 01-27-2012, 06:56 PM
yea of course which confuses me
Old 01-27-2012, 06:58 PM
EK9
Dc4LsTeG's Avatar
Are you sure the tube is all the way in the block?
Old 01-27-2012, 07:25 PM
civicjunkie17's Avatar
When are you checking the oil? If you check the oil right after the car is running or right after you poured the oil in the car doesn't allow the oil to drain all the way to the pan. Check it in a few hours after not running the car?
Old 01-27-2012, 07:52 PM
guess_who's Avatar
Do you have an aftermarket oil pan? could be more than 4qts?
Old 01-28-2012, 05:02 AM
Turbo-LS's Avatar
Sounds like dip stick tube isn't all he way into the block or larger pan ? D series dipstick?
Old 01-28-2012, 07:25 PM
checked twice with 2 different dipsticks it is a b series dipstick. the motor was assembled by someone else, maybe the dip stick tube needs to be fixed. is it possible to fix it without pulling my turbo setup (manifold, downpipe, wastegate) ?
Old 01-28-2012, 07:30 PM
EK9
Dc4LsTeG's Avatar
Maybe depends on your manifold and everything. Maybe try tapping the top of the tube to make sure its all the way in the block
Old 01-29-2012, 05:06 AM
Turbo-LS's Avatar
Just look down at the tube. If the little ring around it isn't fully seated to the block then you know it's not all the way in. I couldn't get mine to go all the way in on my c
Block for whatever reason but I know that the low oil mark on my dip stick is actually reading full
Old 01-29-2012, 03:06 PM
R.I.P. Mark
MRGRIM's Avatar
i own 6 motors and they are all the same
tube DOES NOT SIT ALL THE WAY DOWN
3 JDm 1 USDM 2 AUDM
OP do an oil change and mesure the amount you put in in spec with your engine
Old 01-30-2012, 03:06 AM
Nailclipper's Avatar
i have a turbo Ls/V and i put in damn near 4-3/4 quarts to bring it up to full. if you know for a fact that the dipstick tube is in correctly and you do not have an over size pan , that should do it. depending how long your oil line is and the oil feed for the head, they COULD hold up to 1/4 of a quart.
Old 01-30-2012, 03:25 AM
v8killaz's Avatar
is the car running or is the car off when you check it.
i know to some it may be a stupid question but my freind who thinks he knows all about cars had a turbo teggy and would always tell me the car was burning oil and ate through 4 qts again. one time when he called me complaining i just jokingly said the car is off right. and he was like no the car is on.
i was like wtf is this real life
Old 01-30-2012, 02:45 PM
Jeffaj20's Avatar
Ok, stupid question... lol
But are you checking to see if the dipstick is wet? Cause i've done that before wondering why there wasn't any oil and it was just really clear.
Old 01-31-2012, 08:32 PM
93h2beg's Avatar
i had a customer car come in, he said a similar thing. that even after a oil change nothing on his dip... i pulled it out and sure enough nothing on it, also the dipstick was broken off and was short about an inch....
Old 01-31-2012, 09:07 PM
v8killaz's Avatar
wonder there the other piece was
lol
Dual Cam Killer
12-12-2009 06:37 AM
ITS_Dunn
03-16-2006 04:51 AM
DRKSol
09-17-2005 02:35 PM
JustinL
05-23-2005 06:15 AM
Yamzz_EG
05-18-2003 11:38 PM
Quick Reply: LSv Turbo - No oil on dipstick
