need help finding a top mount
Old Feb 9, 2012 | 01:42 PM
denoel80's Avatar
Default need help finding a top mount
Im looking for a top mount t3 tubular manifold for my b18b. I was wondering if anyone ever came across one that allows you to keep power steering also. I've been searching around for a while and all i can find are ones that require no PS. Im not even sure if its an option to have PS with tubular topmounts. Any help would be greatly appreciated. Thanks
Old Feb 9, 2012 | 06:46 PM
Turbo-LS's Avatar
Default Re: need help finding a top mount
Contact CTD-fab on here
Old Feb 9, 2012 | 08:29 PM
hybrdthry911's Avatar
Synapse Motorsport makes one that is power steering compatible. Here is one that uses the tial v band but i think they make a t3 one as well.
http://www.synapseturbo.com/mm5/merc...turbomanifolds
Old Feb 11, 2012 | 06:51 AM
denoel80's Avatar
thank you
Old Feb 11, 2012 | 08:12 AM
JRSC01GS-R's Avatar
I used the synapse turbo vband top mount i was able to keep ps by shaving the bracket similar to what u have to do with a ramhorn
Old Feb 12, 2012 | 02:54 PM
denoel80's Avatar
Well all the topmount t3 manifolds say PS needs to be removed. What I'm wondering is what's actually in the way. Are the pipe bends getting in the way or is the Turbo and filter. I guess if I just get one ill see if I can make it work and if not ill just remove my PS. It can't be to bad w/o PS.
Old Feb 12, 2012 | 03:14 PM
CDecker0218's Avatar
Synapse Turbo is the way to go
Old Feb 17, 2012 | 01:28 PM
denoel80's Avatar
Thanks for the advice guys. I decided to get a vband exhaust housing for my precision 5857 and i ordered a topmount vband manifold from Synapse Turbo. I think ill like the new setup.
Old Feb 20, 2012 | 05:57 PM
CrackingVTEC's Avatar
Depends on how much money you have.. The sky is the limit if you have the Cash..
93grayeg
Jul 19, 2013 01:20 AM
TurboEK9Coupe
Nov 14, 2007 03:58 PM
rorik
Feb 19, 2006 12:29 PM
ctownintegra
Feb 6, 2006 10:31 PM
PSI2HI
Welding / Fabrication
Jan 21, 2005 10:28 PM
