bearing choice
Old Jan 15, 2012 | 01:55 PM
boostontheD's Avatar
Default bearing choice
i am build a sleeved gsr motor and wondering what the best bearing choice is.
mainly asking this the the guys making 700+ whp.
my build will be that much or more.
now there are the normal acl bearings that i could get.
also there are acl bearings that are coated and the price is twice as much.
are the coated bearings worth the money?
Old Jan 15, 2012 | 09:51 PM
CO_RaceFab's Avatar
Default Re: bearing choice
No
Old Jan 16, 2012 | 05:04 AM
Turbo-LS's Avatar
There are duraglides and race bearings. for your application i would go with race bearings. Check what size bearings you mainly have on your engine and then will determine if you need over or under or standard sized acl's
Old Jan 16, 2012 | 06:35 AM
thankyou i appreciate the info
Old Jan 16, 2012 | 06:50 AM
SovXietday's Avatar
Use OEM bearings and size them correctly...
Old Jan 16, 2012 | 08:26 PM
ateg2308's Avatar
What about King Bearings? Does the honda community have alot of experience with them?
Old Jan 16, 2012 | 10:42 PM
Redline130's Avatar
I've used Clevite bearings for the past 3-4 years with zero issues (same set). Going to be changing them out finally for a fresh set. I'm not over the 700hp mark however (660+). Price isn't too bad either.
goat86
Apr 19, 2014 12:00 AM
Charlie Moua
Jan 16, 2012 07:01 PM
karnieflk
Jul 13, 2008 07:21 PM
marcussmith26
Jan 17, 2006 02:45 PM
1.8T_EG
Feb 19, 2003 06:55 PM
