Stuttering...
Old Feb 11, 2012 | 05:46 AM
shifts's Avatar
Default Stuttering...
It is a b18c5 that starts to stutter after being warmed up for 5-10 minutes. I have changed the plugs and wires but to no avail. I am doing the distributor cap and rotor as well as the fuel filter on Monday. When you push the gas it feels like it wants to go but just doesn't as it should. I feel like gases are building up almost as if it needs to "fart" and then after a while it finally goes normal. Any ideas? I am confused as to why it only does it after warming up...
Old Feb 11, 2012 | 05:51 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Stuttering...
Where's the turbo part of he question?
Old Feb 11, 2012 | 06:17 AM
shifts's Avatar
Well it's a turbo'd engine so thought this section would be more appropriate than the n/a section.
Old Feb 11, 2012 | 06:42 AM
The Grumpiest
So far nothing you've said indicates a turbo issue. Get back to us on Monday after you're performed the rest of that tune up.
Old Feb 11, 2012 | 07:30 AM
shifts's Avatar
Or you could actually provide some actual input?
Old Feb 11, 2012 | 07:33 AM
The Grumpiest
I did. Finish your tuneup. I didn't think that was so hard.
Old Feb 11, 2012 | 07:35 AM
shifts's Avatar
K, let's say I finish it and still doesn't fix my issue. What would be your recommendation?
Old Feb 11, 2012 | 07:44 AM
The Grumpiest
Really? And what if that DOES fix it?
Just do the damn tune-up and stop wondering about what ifs and cross that bridge when you come to it. That's not how you troubleshoot car problems. I could play what if all day long.
Because after that I'm going to ask you to list everything about your turbo setup including your EMS and what your AFRs are reading during the stuttering.
Old Feb 11, 2012 | 08:26 AM
DPancoast's Avatar
What plugs are you running and what are they gapped to
Old Feb 11, 2012 | 08:58 AM
shifts's Avatar
NGK BKR7E gapped to .30.
Old Feb 12, 2012 | 07:46 AM
skateboard_ej8's Avatar
im hench irl
.30 gap seems too big. Try .25-.22
Old Feb 13, 2012 | 10:11 AM
shifts's Avatar
Update:
I changed the cap and rotor. The previous cap did have cracks but unfortunately my stupid self overtightened and created new cracks on the new cap . I'll have to wait till Wednesday for a new one.
I also changed out the fuel filter and replaced my thermostat since it had been fluctuating just to get rid of that variable, which it did .
I am about to re-gap the plugs and then wait for the new cap.
Old Feb 13, 2012 | 10:23 AM
tron_'s Avatar
10 Year Member
Get the cap/rotor on, check the spark plug wires, make sure your base timing is correct, and pull the plugs/inspect them. Regap them if necessary, sounds like your gap is a little on the large side.
Also lol @ the farting b18c5
shifts's Avatar
Ah yes, I also checked timing mechanically and it is good.
Old Feb 13, 2012 | 11:08 AM
shifts's Avatar
I just re-gapped the plugs and all were white except for cylinder 4, which was black. I am ordering a uego and will have it installed this weekend...
Also, it is now sounding like a Subaru as if I am not running on all cylinders. I have contacted a local to see if I can switch out the distributor with a known good one.
Old Feb 13, 2012 | 02:55 PM
MiraiZ's Avatar
Keeping an eye on you too...sounds similar!
Old Feb 13, 2012 | 03:19 PM
crvtectim's Avatar
Hold up, man. Your distributor is working fine if it's firing all but one cylinder. Unless the rotor button isn't contacting the prong in the cap, not likely. Pull the number 4 that was black and check if it's getting spark. Sounds like that one wire is bad.
Old Feb 13, 2012 | 03:34 PM
shifts's Avatar
I pulled number 4 wire from the distributor and it shows spark. I pulled the plug and it showed a weak orange yellow spark. Distributor coil bad?
Old Feb 13, 2012 | 04:05 PM
MiraiZ's Avatar
Sounds like the coil or igniter to me...changing out the Diz should confirm it
Old Feb 13, 2012 | 04:07 PM
crvtectim's Avatar
No, just a bad wire. But I'd replace all 4 of course. Check spark at the other 3 plugs to compare. Don't bother with checking any more at the cap lol.
Old Feb 13, 2012 | 04:18 PM
wwcrxww's Avatar
im thinking its your coil. when it gets hot it breaks up.
Old Feb 14, 2012 | 07:18 PM
shifts's Avatar
Possibly but now it is stuttering all the time but I have a distributor to switch out, I'll also get other wires. If that doesn't fix it, I'll check ground connections and test my map sensor. I've been doing some research and starting to become paranoid of what it could be. Let's just hope it is indeed the distributor.
Old Feb 15, 2012 | 03:51 AM
The Grumpiest
Spark should be bright bluish white. Not yellow.
Old Feb 17, 2012 | 07:00 AM
shifts's Avatar
It was the distributor. I tried the locals and it has fixed the issue. Something I noticed on my old one was the one of the wires was disconnected or better yet just torn and obviously not making any connection. I have crimped those wires but have yet to put my distributor back on but at least I know what the issue is now. I appreciate everyone's contribution from the community .
Old Feb 17, 2012 | 06:39 PM
MiraiZ's Avatar
I got mine running too..I think it was a combination of plug wires and ignition coil. After I replaced them, it fired right up
thanks
Lude #1
11
Jan 9, 2011 01:05 PM
ej8ster96
Aug 11, 2009 04:27 PM
H1PNOT1C PRELUDE
Jul 13, 2004 07:12 PM
xsnrgsr
Apr 29, 2002 08:36 PM
