Walbro 400lph???
Old Feb 2, 2012 | 08:43 PM
Laojoeturbo's Avatar
Default Walbro 400lph???
Anyone running this fuel pump? I know that you have to modify your hangers a bit to make it fit since the diameter of this pump is bigger, but can I run this pump on the factory lines that connect to the top of the hanger? I have heard it is E85 compatible and not E85 compatible. Can people who has or currently running this pump chime in on their experience with it?.... thanks.
Old Feb 3, 2012 | 06:34 AM
Default Re: Walbro 400lph???
nobody tried this pump before??
Old Feb 3, 2012 | 07:08 AM
LocoJoe's Avatar
If you try searching before asking a question that has been covered, you might get an answer.
http://lmgtfy.com/?q=hondatech+walbro400
Old Feb 3, 2012 | 08:02 AM
92frostwhtdb2's Avatar
as far as i know theres no modification to the hanger needed,aleast i didnt haven't to do any.. just dont use the sock provided as it doesnt sit flush in the tank and will starve the pump when it gets to a certain level..im using e85 but havent gotten a direct answer from walbro yet.
Old Feb 3, 2012 | 08:29 AM
Turbo-LS's Avatar
Search someone just recently did a whole write up on how to install this pump with detailed pictures and instructions
ohsnapzafingcu
Nov 17, 2013 08:20 PM
jdm_h22
Mar 4, 2013 07:15 PM
ahobbs
Feb 23, 2011 11:08 AM
Rob!
Oct 13, 2005 03:41 PM
recall
May 5, 2002 04:11 PM
