G.E sandwhich plate fittings
Just ordered a Golden eagle sandwhich plate
Does anyone know what size fitting it comes with and what size feed line I should get.
I have a t3/t4 turbo
Re: G.E sandwhich plate fittings
http://www.go-autoworks-store.com/goprotuoilli.html
or you could prob just get the line and fittings if you have a return line already. If not buy this complete kit.
http://pbckt.com/pr.NF7GrX
http://pbckt.com/pr.NF7A2K
The small hole came with a plug but the big one is 1/8 to 8an do the sell a 1/8 to -4 or something
kinda confused by ur question
As shown in the picture you have a the 8an fitting...that goes to the head to supply oil ...
The other fitting ur using for oil feed to turbo that going to be a 1/8"npt for a 3am feed line.
http://www.go-autoworks-store.com/gooilfelikit.html
just but the kit above...problem solved.
Does it matter what port I use
I'll just buy that kit it's cheap
Does it fit into the 3am
And I'll just buy a 1/8 plug
from the looks of it that kit comes with the 1/8 NPT 3-an fitting. and the fittings at the turbo as well....just use everything in the kit, liek you said its cheap. keep what u have as a spare....Journal bearing t3/t4 do not require a restrictor im not using one on my 60 trim
Does anyone know if a electrical oil pressure sending unit will fit on the sandwhich plate or will it hit the block,
I could go mech.
I could go mech.
Use whatever line works. I had one extra so I used it. It was a -4an line that I used a 90º fitting (1/8npt to -4an) and then adapted the other side back to fit the sending unit (1/8npt i believe)
Do you're self a favor and call the turbo manufacture to find out exactly what sized feed line an if it needs a restrictor. As for the plate I know it has a 1/8npt and the other I'm not sure possibly 1/2
