Budget LSV build- input welcome
Old Jan 24, 2012 | 07:22 PM
ay_billy's Avatar
Default Budget LSV build- input welcome
I am building my car back up, I need input on what to do.
Im starting with a stock 96+ ls bottom end. b16 head. 70 trim t3/t4 goautoworks topmount.
Already turbo, but I blew either a ring or ringland. I obviously dont want this to happen again.
Plans:
Stock bore. No Sleeves
Wiseco or Arias low comp pistons. Whatever I find cheaper
Stock rods, shot peened,ARP rod bolts (are eagles worth the extra 250)
ARP head studs
Cometic or Honda head gasket (opinions wanted here)
New Oil pump ?
Any other suggestion while everything is apart? Like head wise or?
Goals
250-300 hp with decent drivability mileage and reliability. It made close to 400 on this setup, but it didnt hold so I am going for a more reasonable goal since I might DD this.
Old Jan 24, 2012 | 07:45 PM
digital sol's Avatar
Default Re: Budget LSV build- input welcome
Plans:
ARP head studs
New Oil pump ?
Goals
arp head studs, oem headgasket
Old Jan 24, 2012 | 07:57 PM
Divers's Avatar
If you broke a ringland I would suggest a new tuner.
New OEM oil pump (P72/P73)
Headstuds
Pistons AND rods
OEM bearings
OEM headgasket
350-400hp all day long for years with that block
Old Jan 24, 2012 | 08:04 PM
ay_billy's Avatar
Headstuds
Pistons AND rods
OEM bearings
OEM headgasket
GSR oil pump?
Are the rods really needed? Ive never seen a rod break.
Old Jan 24, 2012 | 08:13 PM
gwarfare's Avatar
Go talk to circuit form engine works speak to jimmy tell them Dave with the copper ek9 sent u, this guy is sick in building motors and has one of the best machine shops around. He is in SB off the 215 and the 10 fwy.
Divers's Avatar
GSR oil pump?
It use to be a type r pump, but they are the same number now.
I would do rods if building a motor. It will fart 350-400hp with no worries.
If you're only going to make 250hp why even rebuild the motor? Just buy a used longblock and make sure to tune it this time.
Old Jan 25, 2012 | 12:04 AM
DirtyDA9's Avatar
The ealges are worth it. I wouldn't go with expensive pistons, and cheap out on the rods. They are very good insurance.
Old Jan 25, 2012 | 09:46 AM
ay_billy's Avatar
Im going to start looking for a good set of rods.
I want it to be reliable.
Everyone I've talked to seem to agree the ringlands were blown due to stock pistons, and no crankcase ventilation. It was tuned by a reputeable shop.
I ended up with wiseco pistons. I will look for rods
Old Jan 25, 2012 | 11:54 AM
TheShodan's Avatar
Moderator
good choice, stay above 9.0:1
Old Jan 25, 2012 | 01:15 PM
ay_billy's Avatar
When I looked up part numbers, there was no difference between the oil pumps. I read that 96+ integra oil pumps are all the same.
Is that true?
Old Jan 25, 2012 | 06:32 PM
BigMike0147's Avatar
Yeah, they are all the same when obd2
Old Jan 25, 2012 | 07:43 PM
ay_billy's Avatar
Thanks. That saves me some coin
Old Jan 25, 2012 | 08:40 PM
phaphon's Avatar
Make sure u get a water pump and yeah for the little price I would pay for the rods Cuase they will charge to remove and install the piston and you have to machine the rods it all adds up plus you hqve to buy the Arp rod bolts price difference is not to much Cuase if u do need a need rod in the end u will end up spending more money
Old Jan 25, 2012 | 10:38 PM
Joralex's Avatar
Sorry to ask but, why would you wouldn't want to sleeve the long block?
It would be better just to stay on the safe side, right?
Old Jan 26, 2012 | 06:28 AM
ROMEO856's Avatar
here's our budget lsv build...
http://www.b20vtec.com/forums/track-...car-build.html
Old Jan 26, 2012 | 11:43 AM
DirtyDA9's Avatar
For an LS engine, you don't need it till 450-500hp on boost.
Old Jan 26, 2012 | 01:00 PM
Golden Eagle's Avatar
If you want to boost over 20 psi. Sleeve it @ 84mm
Eagle H beam rods
Arias Racing pistons 9.5:1
ACL STD Bearings
G.E. OEM Head gasket 84mm
Balance the rotating assembly, micro polish crank and check piston wrist pin fit.
''Break in and tuning are key''
cadeMFjohnson
Aug 4, 2009 03:14 AM
blue_hatch
Oct 24, 2008 10:40 PM
CRX MASE
Jun 19, 2006 01:22 AM
drvfast
Apr 28, 2004 07:37 AM
specie
Dec 18, 2002 07:47 AM
