Newb Engine Builder: I Question, U Answer
Old Feb 14, 2012 | 06:13 AM
92egkirt's Avatar
Default Newb Engine Builder: I Question, U Answer
Well let me start by reasons I've started this thread. I've started this thread because there are a few question I have about engine building and this may help other new engine builders that may have the same questions. I do more then reasearch all question on "google" and i know how to use the H-T search bar but search search doesn't give me a justified answer, so I have resulted to come her and make a thread.
What is "piston to wall clearance"? Is this Bore + Wall clearance of the cylinder wall?
How do we adjust "piston to wall clearence"?
How do I measure Piston to wall clearance correctly with a dial bore gauge?
What is "zeroing" the dial bore gauge?
Is this placing the gauge to the desired wall clearance then measuring the "bore"?
For instances the bore gauge is "zero" to .0030" and the bored is 81.5 mm =3.209" when the cylinder bore is measured it should read 3.209 correct?
For instance say you have a bore size of 81.5mm = 3.209" and your recommend wall clearance is 0.0030". Does this mean the overall bore should be 3.212" ?
Sorry for my Grammer,
Thanks
http://forums.evans-tuning.com/viewt...r+engine+build <-(Thanks to Evans-Tuning)
Old Feb 15, 2012 | 02:54 AM
7rrivera7's Avatar
Default Re: Newb Engine Builder: I Question, U Answer
After Google, Youtube has always helped me visually:
https://www.google.com/search?q=pist...rlz=1I7ADRA_en
Old Feb 15, 2012 | 04:07 AM
grumblemarc's Avatar
The Grumpiest
Like I told you in your other thread. If you cannot do unit conversion and add two numbers together you're in trouble.
Watch the video! They show you everything you need to know.
The definitive gsr engine build article
by boosted hybrid » March 28th, 2004, 9:01 pm
VIDEO AVAILABLE HERE
Old Feb 15, 2012 | 07:10 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It is obviously exactly what it says it is - The distance between the piston and the cylinder wall.
Bore/Honing.
With a dial bore gauge and micrometer.
Turning the gauge so it reads "0". (Obviously.)
You do realize the gauge won't change measurements as it's just a device that measures?
What? Stay in school - don't sleep in math class.
Been drinking coffee have we? 3.209" + .003" = 3.212" ... Are you wanting us to check your homework too? Just so you know 81.5mm = 3.208661 - Cutting corners in engine building is never a good idea...
Grammar.
Thanks
Any time.
OP - Please, just do yourself a favor and let somebody "qualified" do your engine work for you. Everything you asked is the upmost basic engine building principles. As stated before, all this information is readily available on the Internet.
Old Feb 15, 2012 | 01:52 PM
Rickcrx's Avatar
1.0mm= .03937
81.5mm x .03937= 3.208655
Old Feb 15, 2012 | 02:07 PM
Whiterice-gsr's Avatar
ok i think i know what hes asking, if your bore is 81.5mm and the recommended piston to wall clearance is .003 then what u want is a piston thats .003 smaller than the bore so the math goes 81.5mm - .003 and that equals the piston size but i know that 81.5 will be your piston size so the bore should read .003 over the piston size. your wall clearance is determined by taking the bore size and subtracting the piston size this will give u the wall clearance. get everything into the same units of measurement and write it all out.
Old Feb 15, 2012 | 02:30 PM
92egkirt's Avatar
Thank you very much, as i am to a visual person, I cant learn from reading things. More of a hands on person.
For the most part I've figured it out.
From Cp Spec sheet
Cp calls for .0035" pistons to wall clearance
Bore size is 3.327
Piston size is 3.3235
Difference from the cylinder wall and the .0035"
In the video of "evans tuning" he wanted .004 clearance. I did the math it would be 3.3275 not 3.328 like he said. Did he just round up?
http://www.youtube.com/watch?v=mpy_By5aIxM
Old Feb 15, 2012 | 02:36 PM
92egkirt's Avatar
exactly Thank you for explaining it, I figure the piston would be exactly 81.5
(3.209) but appearently the pistons is smaller and 3.209" is the bore size of the cylinder and if the mfg of the piston calls for .003" then the piston size is "3.206" to give you that .003" of piston to wall clearence".
Please correct me if im wrong.
Old Feb 15, 2012 | 02:43 PM
u bore the cyl to what size of piston u want to run u can virtually make it any size u want. take it to the machine shop and tell them u want this size of bore and they will do it for u. what engine are u building?
TomCat39
Engine Machining & Assembly
Nov 24, 2018 07:58 PM
92egkirt
Feb 16, 2012 03:44 PM
bumblebee-tec
Jul 8, 2007 08:24 PM
IN VTEC
Jul 10, 2004 06:28 PM
B18CHatch
Oct 21, 2001 04:53 PM
