Advice needed: Cam Setup-- Engine builders chime in
Old Jan 17, 2012 | 05:38 PM
wreckeddc4's Avatar
Default Advice needed: Cam Setup-- Engine builders chime in
Im just finishing up my ls/vtec build setup for nitrous. I originally had the engine setup with stock pistons for an all motor build, and used an oem 3 layer head gasket. I degreed the cams when I first put it together. Plans for the engine changed a little, decided to go to forged pistons, eagle rods and a big nitrous shot.
Now to get the compression I want, I used a 2 layer headgasket. I know this changes the cam timing a bit, but my issue is I borrowed the equiptment to degree the cams the first time. I just need the engine to be runable. Doesnt need to be driveable, I just need to get other **** done on the chassis, in the meantime, setup some wiring and electronics.
Right now, with the cams where they would be on TDC, the TDC mark on the crank is about 1/8" past the TDC line on the timing cover.
I think if I rotate the cams towards the front of the motor 1* at a time on both till they are close to having everything where it should be, that I can at least start the engine and finish everything else that needs to be done while I wait for the weather to turn so I can get the tools I need to do it right.
I already plan to take the cams back out to check the headstuds after a heatcycle on the motor. So I will degree the cams before I drive it or have it tuned at all.
Old Jan 17, 2012 | 11:43 PM
rich7777's Avatar
Default Re: Advice needed: Cam Setup-- Engine builders chime in
Whats the question ?
Old Jan 17, 2012 | 11:56 PM
mmcd's Avatar
i was thinking the samething?
Old Jan 18, 2012 | 02:14 AM
wreckeddc4's Avatar
My fault, I tend to babble sometimes.
Would it be safe to est my cam timing for initial startup?
Old Jan 18, 2012 | 03:16 AM
rich7777's Avatar
That looks out to me. Pull the harmonic damper off and check how its lined up against the oil pump and cams. You need to set the cambelt up correctly before anything.
Old Jan 18, 2012 | 03:34 AM
wreckeddc4's Avatar
I will double check the belt again tonight.
Old Jan 18, 2012 | 04:37 AM
00Red_SiR's Avatar
All Motor Mentor
First question I have is what cams are you running that would require you to degree them in? You'd have to remove .040" from the head before you'd need to correct cam timing 1 degree, you only removed .010" so no correction is needed. If your going to tune your cams on the dyno, you really don't need to worry about deferring unless you're running something like the pro series cams.
Old Jan 18, 2012 | 05:04 AM
wreckeddc4's Avatar
Thanks for the input, that's more of what info I was seeking.
I'm using a blox tuner stg 2 cam, I know it's typically a drop in cam, but when I used them before, I degreed them to the specs they came with, and they made great power with my NA setup.
Old Jan 18, 2012 | 05:54 AM
kyden's Avatar
am i seeing this right? the exhaust cam is +6?
Old Jan 18, 2012 | 05:58 AM
00Red_SiR's Avatar
All Motor Mentor
Could be at -2 as well. Hard to tell in the pics.
Old Jan 18, 2012 | 06:04 AM
wreckeddc4's Avatar
It's hard to see in the pic but they are both advanced. I forget the actual numbers off the top of my head. +6ex +3intake but I can confirm after I get home.
Old Jan 18, 2012 | 05:52 PM
wreckeddc4's Avatar
I reset the timing belt and it lined up great. I started it and it idles smooth.
Thanks 00Red_SiR for the info
TegLK
Engine Machining & Assembly
Mar 7, 2018 07:30 PM
Listerofsmeg
Jan 16, 2012 06:50 AM
PinkMaggit
Mar 18, 2006 11:34 PM
Jdmglenn
Jan 16, 2005 10:30 AM
mkmoto
Jul 1, 2004 06:05 AM
