BKR7E Plugs
Old Jan 31, 2012 | 06:44 PM
MrDomino's Avatar
Default BKR7E Plugs
This is probably an obscenely basic question but I don't want to end up with a bunch of plugs that I can't use. When I search for BRK7E is that enough to specify which plug I want or are there different thread sizes/diameters, etc?
Also, I'm probably going to order 5-6 sets for tuning. Where can I find them the cheapest?
Old Jan 31, 2012 | 06:53 PM
TheShodan's Avatar
Moderator
Default Re: BKR7E Plugs
You don't need 5-6 sets for tuning.. that's a bit overkill. One set will do
Here's what you need to go by for the NGK part. But there is also a stock number
then purchase here:
http://www.sparkplugs.com
Old Jan 31, 2012 | 07:20 PM
MrDomino's Avatar
I'm planning on doing several tuning sessions as I test some things out so I'll probably need to order more at some point. From what I've heard you're supposed to put in a new set of plugs and then do a pull on the dyno or the street and then shut off the motor and let it wind down and then take out the plugs.
Old Jan 31, 2012 | 09:47 PM
racebum's Avatar
that's an old school way to look for detonation and rich/lean conditions
now a days you use a wideband
have a chat with your tuner of choice about what you need and what he will do
Old Jan 31, 2012 | 10:33 PM
komat's Avatar
your local part stores should carry them at 1.99 each
ask for 95 audi s5 or s6 spark plugs.
Old Feb 1, 2012 | 02:43 PM
sonicivic's Avatar
4644 is the part number i believe
Old Feb 1, 2012 | 04:59 PM
SiRCiviC94's Avatar
how much are people boosting on these? when should 8s go in?
Old Feb 1, 2012 | 06:10 PM
blackeg's Avatar
i switched from 7s to 8s at about 450whp on 10:1 compression and noticed a little bit of a difference. im sure that number is arbitrary but it gets you thinking
Old Feb 1, 2012 | 06:40 PM
MrDomino's Avatar
I am the tuner. I wrench and tune my own ****. Looking at plugs can give you insight about timing.
Old Feb 1, 2012 | 06:55 PM
Bunta Fujiwara's Avatar
After I've finished tackling the corners of Akina in my WRX STi 22B, I sometimes need to replace my plugs.
I've found that NGK BKR7E11 or BCPR7ES are basically the same plug except the BCPR has a slightly larger connector to the plug wire.
Amazon or Ebay are usually cheapest.
Happy Drifting!
Old Feb 2, 2012 | 03:55 AM
sonicivic's Avatar
its always been my understanding that when the mark on the heatstrap gets past 3/4's of the way then you are ready for the 8's
my car is on the verge of needing 8's in it at 22 psi
Old Feb 2, 2012 | 07:07 AM
SiRCiviC94's Avatar
^ i know this, but on average what power is that? and how do you do a plug test on a turbo car you would have to wait 2-5mins idling before shutting down instead of a wot/shut down plug check which is dead relaible
Old Feb 2, 2012 | 07:34 AM
LightningTeg's Avatar
Community Builder
4554's are the 8's you want to run. From my research all the tuners love em and they fixed my break up issues.
Old Feb 2, 2012 | 09:12 AM
blackeg's Avatar
Yes they helped me run better on my higher boost pump gas. I was seeing some small evidence of detonation on the 7s, the 8s are clean on the porcelain
Old Feb 2, 2012 | 09:14 AM
AcuraIntegraLS-T's Avatar
Those are non-resistor type not a good idea if using the stock ecu for tuning, not sure if it effects standalone stuff.
Old Feb 2, 2012 | 10:57 AM
Garage 808 Hatch's Avatar
I use the 7173 stock number NGKs. they are a resistor type 8
Old Feb 2, 2012 | 11:42 AM
SiRCiviC94's Avatar
links would help for what plugs to order I need to tune between 240-300hp for now. All I have ever ran was a bkr7e-?
Old Feb 3, 2012 | 05:58 AM
kyden's Avatar
you'll be fine with the 7s. 4644 is the part #
Old Feb 3, 2012 | 10:34 PM
vwbased's Avatar
have a nice day
Old Feb 3, 2012 | 11:15 PM
DC4KiD's Avatar
You can also use Champion 344 plugs, they are the same as the NGK BKR7E plugs.
Old Feb 4, 2012 | 02:53 PM
MadVTI's Avatar
We use bcr8es, great results to over 500who and cheap as chips
Old Feb 5, 2012 | 10:56 AM
xenocron's Avatar
http://en.wikipedia.org/wiki/Spark_plug#Heat_range
Understanding heat range is important. You can run a range of plugs in a motor and they will work, and they will not affect power output of a motor (if all other parameters are equal)
Run too hot of a plug and you can cause pre ignition...run too cold of a plug and it will not self clean well and you could be changing your plugs frequently.
Also if you like to read plugs while tuning (on the dyno, at the track etc) then they will at least need to be close to a proper heat range in order to be read properly
Old Feb 5, 2012 | 09:24 PM
SiRCiviC94's Avatar
ok bump where is the cheapest place to buy these online! I need atleast 12
Chillinit
Oct 24, 2005 10:00 PM
1.8
Apr 11, 2005 12:19 AM
nsx-Animal
Jul 30, 2002 04:22 AM
JohnnyBoy
Dec 3, 2001 04:20 PM
Ri5e
Sep 10, 2001 11:26 AM
