Lightweight Crankshaft B18C
Old Jan 24, 2012 | 02:40 PM
gtm_maxwell's Avatar
Default Lightweight Crankshaft B18C
Hi anyone know any good quality Lightweight Crank?... how was it compare to normal Crank?..
I was thinking to get a Lightweight Crank for my B20B... any Suggestions...
Old Jan 24, 2012 | 02:46 PM
96GeeSR's Avatar
Default Re: Lightweight Crankshaft B18C
Why?
Old Jan 24, 2012 | 02:53 PM
Turbo-LS's Avatar
wait you want a lightweight crank for your b20b but you posted looking for lightweight crank for b18c ?????
In any event there is not need for a lightweight crank in a honda engine unless its an all motor and yur trying to extract every drop of power out of it and completely reduce motating mass down to minimal and your talking about a crankshaft that will cost more than most people can afford. leave it stock
Old Jan 26, 2012 | 02:00 AM
Em i m using the b18C crank in my B20B block... so i was wonder if any one have reduce the weight for the crank and fit into the B20B block...
I try to increase the accelerations for my motor... which i have already install a Aluminium Rod for my B20B engine build but i was thinking to reduce the weight for the crank as well... but not sure what will be the problem after reduce the weight... any advice?
thx
Old Jan 26, 2012 | 04:51 AM
SLIM NOTHING's Avatar
so you want to using b20 alum rods on a b18c crank in a b20b block?
Old Jan 26, 2012 | 05:45 AM
Turbo-LS's Avatar
I think he speaks broken english, he is building a b20 block probably for the 84mm bore but going to run b18c internals.
Old Jan 26, 2012 | 07:17 AM
SovXietday's Avatar
You're better off having your crank knife edged and balanced than trying to deal with an aftermarket crank. The last thing I would ever want to swap for aftermarket on a Honda is the crank.
Old Jan 30, 2012 | 05:00 AM
thx that is what i mean... i m using the B18C crank and rod inside my B20 Block :D
Old Jan 30, 2012 | 05:02 AM
noted.... so better stay with the standard B18C crank just balance or Knife Edged it....thx
JDM_EK4_Coupe
May 29, 2007 06:06 PM
turbotime
Mar 31, 2006 05:59 AM
Jammersplace
Nov 1, 2004 11:21 PM
hb_racer
Jan 24, 2002 11:45 PM
I-VTECRX
Jan 23, 2002 04:58 AM
